o2 sensor after header....
install, i heard of people o2 sensor going bad, i did a search but not much detail as to wat you did to remedy it, and if it was possible to fix....i would like to know if you had the same problem cel numerb p0141 bad o2 sensor....can it be fixed or does it need to be replaced?
thanks
JON
thanks
JON
Hey Jon,
I did my OBX header install on my '02 TLS over the weekend. It took about 5.5 hours, but it's finally done.
Anyway, to answer your question about the O2 sensor, OBX made the plug hole for the sensor too far up, and due to the length of the sensor, the insulated wires will touch the tranny box and the wires will eventually melt and you'll lose the sensor.
HOWEVER, I did manage to get about 2 to 3 mm of space inbetween the sensor wires and the tranny box by simply using a pair of pliers and a small crowbar to bend the top of the sensor away from the box. I tried wedging a piece of ceramic tile between the tranny box and the sensor, but it popped out as soon as I started the car.
I've driven about 75 miles already with the modified bent sensor, and I have not seen a check engine light. I'm keeping my fingers crossed and hope that it'll be okay.
I have no CAI (yet), but I can feel a slight power increase at WOT. I also have resonance at around 2500 to 2900 rpm.
Hope this helps.
G
Hope this helps.
G
