TeknoKing
close
- Join DateJun 2003
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:279 Times in 162 Posts
Hey guys,
I had the car for almost 2 years (00 TL), and I began to realize that when I depress the brake, the car stops, after the stop, then a few seconds later the pedal softly sinks in a little.
Now is that normal and is it done to relieve the tension? Or something is freaken wrong?
The Acura Tranny Killer
Is normal, my 99 does the same, it's the electronic brakes at work.
Tracer
Tracer
R.I.P Red-CL
I had that on mine but noticed that it doesn't do it as much or if not at all when I got the brake pads replaced on my 03TL.
Theoretically, sinking pedal is a sign of failing master cylinder. But if it only sinks a little... I guess you are OK. Mine doesn't sink a bit ('00 TL)
Ak Ting Up
Quote:
Keep a eye on it. It is a symptom of a failing master cylinder or break booster. My 03 TL pedal sinks a little, and so does my 92 accord which has a new master cylinder.Originally Posted by Strannik
Does anyone also think it could be a slight vacuum leak or a weak line too?
I thought that could be a tell tale sign as well - though very minor.
... assuming brake fluid resevior is topped off and such :-)
Quote:
