Is this normal with michelins?
Fallen
O my god.. I almost had an accident..
It happend on the way home, it was little bit raining but no more than a light-rain, the road was reasonably wet..
I was on the street (small two-lane street(including oncoming lane)), i was stopping for a stop sign.
I felt Huge shake when i was braking, and right away i notice that i was the front-right tire.
When i took off, the front-right tire was spinning crazy, i could hear the noise the tire was making and also felt that the tire lost its grip.
I had several more stops and decided to get in to the parking lot near by, and i checked my tire. There was nothing visually worng with the tire, so i tested the car in the empty parking lot. Sharp turns at low speed, braking at low speed and all. The car was sticking on the ground when i was testing it, so i went on the street, with extra care. On next stop, holy crap! the tire lost its grip again. I stopped about 10 inch further from the position i should have stopped. I took off, and tire spun like it has no thred left. I finally got to Yonge street, and made a right turn under the green light, another huge spin during accelerating 0 - 20 km/h.
I had my VSA on too..!
What the hell? I never had this experience even under a heavy shower.
I had to change the passenger side tire and rim few weeks ago because it had two bubbles and a bent rim.
I thought that it was not a good idea to give a new tire on one side of the front wheels since TLs are FF.
Could somedoby help me? Any oppinion will be appretiated. Thank you so much.
Fallen
I have thought of that too.. but I experienced more than one spins and one was on middle of Yonge street... (Started spinning from the centre street which i was on before get into Yonge street).. I saw my VSA light blinking desperately to balance the car...
Dude, don't even bother trying to use these stock michelins in Rain or Snow. I did, and it was hell on wheels. I switched to the Toyo T1-S, and even when it's torentially raining, I can get up to 130 km/h without any slipping. And also, I had to make an emergency stop a couple days ago on Bathurst while it was pouring rain at about 12:30am and I stopped a hell of a lot quicker than I expected, and the ABS only kicked in from 20-0...I went from like 100 to 20 in no time. The toyo's are a phonomenal tire but are definitely noisier than stock, but then again they probably will save ones life in a panic stop situation.
Get a new set of tires, a good all-season will be better than our michelins (Conti-Extreme Contacts, P Zero Nero) or get dedicated summer and winter tires like I did.
Just my .02!!!
Just my .02!!!
Stock Michelins are designed to be hard as rock. This gives Acura a good published fuel economy number for their cars and the entire fleet. Acura put a 6.5 inch wide wheel on the car probably for the same reason.
Get some seperate summer and winter tires. Winter tires are cheap so the time you spend rolling on 16 inch cheapo rubber will save you money in the long run.
Originally Posted by ajNYHC
Can I fit 225 on my stock 03 TLS rims ?
I noticed that you said “it was little bit raining but no more than a light-rain, the road was reasonably wet..” Was that dry for long time before that rain? If it was, here is the problem. Also, over period of dry weather dust settles on the road. When the first rain starts and it’s not too heavy, water mixes up with dust and forms very slippery film, acts almost like oil. That can be washed off the center of road toward the side. Soft rubber tires grip better and, therefore it is less sensitive to a difference between the center and the side of the road in this condition. Your Michelins are quite hard; they don’t stick and would slide/spin easier.
Just my 0.02 ...
Just my 0.02 ...
Originally Posted by hemants
225/50/17 is a better match to stock than 225/45/17 but both would fit.
I recently put on the Michelin Pilot Sport A/S, these are much better than the stock Michelins.
Originally Posted by got_3.2?
haha call me crazy but i dont have ne problems wiht my stock michlens.
Originally Posted by goldendragon576
the stock tires are aweful! Change them ASAP! They make such a HUGE difference between new aftermarkets and the stocks.
Fallen
Just my 0.02 ...
Just my 0.02 ...
That is info from Driver's Ed 101. When there is a light drizzle after a few dry days, watch out! Any road with any tire is extra slippery! Its not only dust, but old rubber, and oils that accumulate on the surface.
Michellins are designed to be softer, not harder, than other tires. Case in point - I had a Taurus with MXV4's all around. Everyone thought my front tires were low on air all the time, but actually they were the same PSI all around. After those tires were done, I bought a cheapo Wal-mart brand. The tires, with the same pressure, looked even and the sidewalls didnt bulge.
The stock TL tires are more for touring, thus have a softer sidewall and better road comfort (noise, bumps, etc..) You lose agility.
The cheapo tires I meantioned before, sucked, and were hard as rocks. I felt every pebble on that road. But you get what you pay for.
Michellins are softer rubber.
Just my 0.02 ...
Just my 0.02 ...
You have to distinguish between sidewall softness and rubber compound.
Appearing low on air is a sidewall issue, not a rubber compound issue.
Softer tires stick better but have lower tread-life. Hard tires like the stock Michelins will last 60000 miles but they may as well be plastic!
I suppose it's possible that a Walmart brand is even harder but that's not saying much.
At ~25-30K of use my Stock Michellins felt like they were buttered in the rain; absolutely terrible traction as they wear. Bought a good pair of Bridgestone Turanzas and couldn't be happier even with 35K on them now.
2400 Watts in a TL...Why?
1 Post
Just my .02!!!
Just my .02!!!
Jeff your tires look like SUV treds |VVVVVV|, lol.. that's why they sound so loud, they for off roading lol, hope you can take a tease.
And he is asking about the Michlens tire not the Toyos. We all know you try to pimp out Toyo tires like they are paying you per km.. Plus you just put a set of crossdrilled and slotted i rotors on and new Green stuff pads on, don't you think that the brand new rotors and pads might have something to do with your stopping quickly?
And the ABS kicking in has to do with how hard the calipers "bite" the rotors. Not how much grip the tires have on the road. I think you are little confused on the ABS issue, you tried to tell Giovanni and myself that ABS only works below 40 km.
I would personally reccomend a visual inspection of each of the front tires, if they look identical, or not damaged. The problem might be, BIG might, be that the treads wear on your front tires are not even. I have yet to hear this as a problem when only one tire is replaced on the front of a FWD car. But it could be possible if you think about it. one tire having 30% tread wear vs the other tire with 100% tread wear.. The tires will actually be different sizes if one is brand new on one is a couple years old. The common practice for replacing tires would be to replace two at a time, either both front tires or both rear tires.
Fallen
I really wanted to swap all of the 4 tires but the bill was already over $1000 for repair.. (Like i said before, Damn pot hole made a big dent and bubles on pessanger side wheel).. I couldn afford to get whole new shoes for my baby... instead I had to give it a new one for what hurts most....
Considering only right side was spinning... there is a possiblility ...
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
