Noisey Windshield Wipers
Just took the first long trip in my 2002 TLS and it rained most of the way. My windshield wipers are making a loud thud/bumping noise each time they change directions from left to right...even when on intermittent. Anyone else have this problem..and is there a fix?
It hasn´t happened yet on my 02 TLS.. but I have less than 1k on it.. : )
I did however notice that noise from the wipers on a 01 CL loaner from the dealer. It had around 9k on it..Very annoying!
*swipe, clunk, swipe, clunk*
Hmmm the wipers on my 2002 Tl-S are a million times quieter than on my Accord. Maybe theres too much tension on the wipers making them press too hard on the windshield??
I also use Rain-X which helps as I use the wipers alot less than before, I rarely use more than the slowest intermittent speed. In slower traffic I may use just intermittent. At nights in the highway, I dont use them at all.
Just call me..................Mr Hyde
TL Type-S Forum Moderator
02 Aegean Blue TL Type-S with Navi
Accord Forum Moderator/Honda-Acura.net
I have noisy wipers, too...but come to think of it, if it cleans, it squeaks.... It's 2 rubber blades rubbing glass in front of you after all, right??
Try some Rain-X, they work very well!!
Andy Kuo
'92 Mercedes-Benz 400SE
Pearl Grey/Black
'02 Acura TL-S
Satin Silver/Ebony, w/out NAV
Andy Kuo
Pearl Grey/Black
'02 Acura TL-S
A thunk is not a squeak - the thiunk is caused by the change in direction on these wipers - a squeak is the result of a resonance caused by slip-stick between the rubber and the glass.
The thunk was on my '99, 00. and the '02. The 02 is the best of the lot - the 00 was the worst. I did notice a difference in how far the wiper sweeps to the left - on the )), the noisiest, it went beyond 90 degress to the horizontal - perhaps to 100 degress. The 02 is 90 degrees - check your car, and if it is much off off 90, have the dealer adjust it.
My 2002 TL-S does this too. It's definitely a "thunk" as the wiper mechanism reaches the end of its travel and reverses (only on "up-strokes" it seems). I think I notice it only because my '97 Maxima SE doesn't make such a sound. But everything appears to work correctly.
Matt
Matt
There is a product by 303 that treats wipers to keep them really soft -- I can't guarantee it, but if you want to have a look, here is the link:
http://store.yahoo.com/autopia/303wiptreat.html
You shouldn't have this problem, but you may have some sticky stuff on the rubber of the wipers. Since I have the CL-S, I haven't heard about this happening on the CLs exactly as you described.
Bosch also makes a graphite impregnated wiper blade that glide over the glass! We had a related issue -- squeaking windshield blades, chattering, etc, and one of the members replaced his OEMs with them -- and highly recommended them. I'm going to give 'em a try, when the time comes.
Here is the link to the "Bosch Micro Edge Wiper Blades" page:
info -> http://www.mailbag.com/users/nosimport/bosch.htm
order -> http://www.autobarn.net/bosmicedwipb.html
(just a suggestion or three)
I had a 91 Accord and had to replace the wiper arm about one month before I bought the used Acura. There is a round plastic clip that rotate on a metal ball on the motor assembly. When the round plastic clip gets worn, the wipers will travel too far and become very noisy, then (as happend to me) they just quit working once the plastic clip wears through cause the rod falls off the motor assembly. Easy fit/junk yard used assembly for $20 and an hour of my cheap labor. Low and behold I buy an Acura with 38k on it and it's a repeat of the Accord noise and wiper traveling too far and hitting the edge of the window frame. I grew up driving my fathers 66 Thunderbird, which had wipers that were OIL pump pressure driven. No motor noise and they were REAL quiet. Guess I'm spoiled. Just hope the Acura doesn't fail like the Accord did in a bad rain storm. Had to drive home looking out the drivers side window! YUK!
Originally Posted by EricL
I use Zaino (kind of like a super Rain/X) on the windshield as well as the paint. I notice that the windshield wipers are very smooth.
Very well put . That is exactly what fixed my problem. Either blades are dried or winshield is not smooth enough.
Originally Posted by songoku
It sometimes happen when you replace aftermarket wiper blades. Try putting different brand or OEM blades.
I did a SEARCH on this awhile back since I suffer from the same problem. Aparently Luke7 is correct. It is caused by a defective design that wears or stretches causing the over travel. In addition, I think I read something like a Jackson for parts and if mechanically inclined, an easy DIY fix. I just have the problem that I always remember about it when it is raining, and by then...
NOTE:
The new replacement rods for my Accord were around $25 a piece. You just access the motor/wiper assembly and pull them off and snap a new one on. This would fix most noisy wiper problems if it isn't the blade. But I'm not sure if the Acura is the same design!
NOTE:
My 1999 TL's blades are thumping so hard I've got to do something. I've read this thread & now wonder if I might be able to fix it. The only thing I wonder is could it be the wiper motor or just the clips everyone talks about. The blades seem to travel random distances - sometimes the blade travel travels the full swing & thunks on the edge of the windshield or travels 3/4 the way up & hits the base near the hood. Anyone experience an erratic wiper travel like this?
Check the clips/you have to replace the wiper arms. Acura/Honda doesn't sell just the clips. Easy fix after you access the arms. Let me know how it goes, since I'll be one of the next people to do the same thing. Mine are getting worse and starting to travel too far. Mine were also inconsistant on my Accord. Sometimes they would work ok but, but when traveling down the highway when the wind was pushing the wipers further, they would really bang on the edge of the drivers side window frame. At low speeds around town they worked fine. It will only get worse as the clips wear more. At some un-opertune time the clip will fail and the arm will pop off. Then you'll be driving with your head out the window wishing you would have fixed them.
Had a similar issue about two years ago before I purchased a transmission "scissor" assembly from a junkyard (items #11 and #12 on diagram shown earlier in thread). A little challenging to get to, took me all of about an hour to do the job. Haven't had one problem since.
https://acurazine.com/forums/showthr...issor+assembly
By the way, just replaced my blades with Boschs. Extremely quiet!!
Motor is fine, just replace the rod linkage (items #11 and #12) u see in the diagram and that will remove the slop you are getting.
P.S. I refer to the rod linkage as "scissors" because that is exactly what they resemble put together. It comes as one assembly, I may have paid $20 for the part from the junkyard.
Wiper Assembly Part Identification
I've gone to 2 Acura parts stores so far & neither person I've talked to had seen this problem & was unsure of what part to order. Do I need the whole scissor assembly (11 & 12) or parts #8 & 9. The low cost on some of these postings leads me to believe it's not the entire linkage. If anybody out there has fixed the erratic wiper sweep problem, I'd love to find out exactly what parts wore down & needed replacement.
Thanks!
Thanks!
Thanks!
Thanks!
they are so loud, i hate putting them on!!!!!!!!!!
Originally Posted by bkzjimmy
thats what i wanna know....i need the part # cause my whipers are gettin on my nerves!!!!!!!!!!!
oh.....is there a DIY or do i have to take it to the dealer??????
76530-SOK-A01 is the part number of the linkage assembly. This is the part I was able to get from a junkyard about two years ago for about $40, and it included both rod units (Parts #11 and #12).
On a scale of 1 to 5, I would give it a difficulty level of 2. If you can change brakes, then you should be able to do this job as well. I don't believe there is a DIY out there. Basically you have to remove the wiper arms, then carefully pop out the plastic caps on the plastic cover thingy that hides the linkage assembly and the motor. Take off this plastic shield and you will see everything. You can pretty much look at the new part and be able to tell how to get the old one off. Took me about an hour and a half to do the job, but it only took that long because I didn't know what I was doing initially. If I had to do it again it would take under an hour.
4.5 year old thread.
