No Power To Drivers Seat
Pulled my drivers seat out last night to do the heated seat repair. Got it done late last night. This morning I went to put the seat back in the car and now I have no power to the seat. Pulled it back out to make sure I reconnected everything, checked the fuses, everything looked good but still no power to the seat. Any ideas? Thanks.
when you say looked good- did you swap fuses or use an actual test meter on each fuse?
note: MUST disconnect battery neg cable before seat removal--
before unplugging SRS connectors under seat,,,or you will trigger a false srs code and light
reset procedure is in our diy section
There are 2 fuses for the seat. Does the seat recline?
does the passenger seat move?
Well that eliminates it being a fuse issue because the only other fuse is the underhood fuse panel fuse 55 which supplies power to the dash fuse panel for the seats fuse. You need to go back and double check your wiring again. Start with the seat switch and make sure its plugged in.
What's that saying....live and learn. Apparently blue doesn't go to blue for the seat controls. I flipped two of the harnesses. I thought they purposefully made the connections different shapes and sizes to eliminate those type of issues. Oh well now I know. I'll go back to marking harnesses with a sharpie to make sure I'm connecting the right one's together. Thanks 01tl04tl and fsttyms1 for helping out.
Glad you figured it out.
rockyboy
08-04-2024 10:35 AM
