No air/heat coming out of my driver side vent
Yes my air/heat is coming out of all my vents except for the drivers side closest to the driver window. has this happened to anybody. And before anybody ask yes the vent is open. All feedback is deeply appreciated
Unregistered Member
Are you ABSOLUTELY SURE you're vent is open?!
Lol jk. If the middle vent (right above the A/C controls) is working, then the driver's side should work. I believe it's tubing is the same source.
Maybe the vent got stuck closed and some plastic broke? Though that doesn't seem likely, as it's pretty sturdy. I've removed that dash piece many times without problems.
Hmm... run a DTC code for the HVAC system and tell me what it says. Turn off car, turn the key to accessory mode (II) (engine still off), and then press and hold AUTO and OFF together.
Does your auto temperature display flash anything?
manual ac/vent controls or the navi dash auto-control system?
can you get heat thru the same vents or nothing at all?
there is a divertor door in the system to direct air that bust a cable stay or similar idea.
any chance you often switch vent modes with the fan on max?
^ Navi control no heat either i would have posted this a while ago but my car still gets cool/hot because of all the other vents gettin air/heat thru them i hope a dead animl isnt blocking my 1 vent somehow. What you mean by switching vent modes?
And thanks again for the help
Yup with Recirculate it should give more Air output..
But its wierd looking at the schematics there isnt any block aside from the Air Vent switching, BUT the Vent switch is local for every vent in front of the Dash.
(Front Left) + (Center Left) (Center Right) + (Front Right)
(Tube) + (Tube)
(Center Switching)
So FL & CL are conected to the same source, So like Karanx7 said the Center Left should have no Output aswell.
(Tube) + (Tube)
(Center Switching)
did the test the display didnt flash anything it just said the temp setting which is "63" no flashing at all.
How do I do vent mode? to see of thats the problem or if this fixes the problem i normally get in go to my nav and hit 3-5 on the a/c settings (depending on how hot it is) with a/c button on.
nanos
11-12-2015 08:41 PM
sockr1
10-01-2015 01:31 AM
