No ABS+ hard left+ brick wall = Bad
#42
Kang Ho
shit! I was going to ask you what happen...Damn man. Fix that shit when you get some money, if not, let me know if you plan to part out. I think I need some stuff.
Look on the bright side, your family still got you.
#43
Sad to hear.... eventually it would have happened though. Yours is of a rare breed and now its out of commission....
#44
COTM Coordinator
replaced lower control arm, and sway bar end link. I was able to drive it to my other friends house where were going to remove the lower front crossbeam and bend it straight..... or atleast attempt to.
id worse comes to worse, ill have to buy the new crossbeam at 150 bucks. I can afford it now, but I would rather try to fix the existing one. since its still bent back, the torsion bar is pushed back and its causing the wheel to be pushed back which is completely fucking with the alignment. so after I try to bend it straight and im succesful, ill go get the alignment done.
I still need a fender, but that I can deal with later. I can roll fenderless for a while.
and since I put my brothers 3G rims on the back tires are rubbing so I have to roll those tabs in.
so that's my little update.....in case you guys were wondering how things were going.
#47
COTM Coordinator
its driveable now, just not very good. yeah I know about steel. im not sure how succesful well be, but its worth a shot at saving 150. were doing that today after work so ill let you guys know.
#48
Well just get the mechanics working for now. A few dents arent that big a deal if you are short on gas. As long as the car gets you from A to B.
#51
COTM Coordinator
its still sad when I drove it last night. it just wasn't the same. I miss being able to go fast, but soon enough I will.
once its fixe im gonna take it easy for a while. no speeding....... well ill try not to lol.
hope I can get it fixed today. the crossbeam is like 80 miles away, so its gas plus 150......
#52
COTM Coordinator
Originally Posted by MurdaZ
Yay
Oh and the wall still isn't fixed......... if anybody was wondering. and ill still post pics....eventually.
#54
Problem is if its not straight they will probably never get your alignment specs normal. If your radius rod is bent you should get a new one (or at least try to get a used one)
#55
COTM Coordinator
the radius rod, or what I've been calling the torsion link, is not bent. the only things that got bent were the lower control and the cross beam... oh and that little tow attachment underneath. the sway bar link snapped in half, and the rim snapped in half.
so if I can get it straight it should be fine, or at most id have to get a new crossbeam..... and alignment.
#57
COTM Coordinator
I will try to get pics....
So I tried fixing the crossbeam and I was succesful
at failing ..... it didt work. So I have to go buy the new/used part.... Oh well it was worth a shot.
#61
Something is missing...my
DerrickW
11-15-2015 05:52 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
