Next on the list
Next on the list
Hey all,
I am not sure if you all know what I have done or have had a chance to look at all my topics but I have been thinking about doing something performance wise next to my car. So far I have added new coilovers, 18in wheels with new tires, a spoiler, and fog lights. I also already had a AEM V2 CAI which has helped a little.
What I am thinking of next is: (these are not in order I am just listing them off the top of my head)
-New Headers
-Exhaust Mufflers
-supercharger
-New Spark plugs
-New Fuel Injectors
-Performance Chip
These are just the ones I can think of that I might replace not all at once but over time. If you know any others that I should consider that will give me some more performance please let me know. If you want you can also list in order what you think I should start with.
-New Headers
-Exhaust Mufflers
-supercharger
-New Spark plugs
-New Fuel Injectors
-Performance Chip
Justnspace thanks for the reply. Alright so as I see it, its best to start with replacing the headers, then new exhaust, and maybe a six speed swap.
Again my car just hit 101,000 Miles.
Timing belt has been done at 88,000 and sparks at 70,000. I think they need to be done but I also want to do something for a HP gain/performance. I think I should start with headers. So I was driving around this weekend and I had a little shake when switching from 2nd to 3rd gear. So I had the trans fluid drained and replaced. Do you think my transmission is about to go at 101,000? I have kept up with all the maintenance of the car.
3.2TLc (03-04-2013)
Have you inspected the motor mounts yet ?
Check with your local Acura dealer if your TL had the tranny recall performed. With your car's VIN#, they will be able to tell you if the tranny was replaced then.
All of a sudden, there's been a switch in gears......from going WOT, to now back-pedaling with tranny concerns. It would be in your best interest to feel confident about the tranny before jumping into performance mods, IMO.
Yes you are correct 3.2TLc. My biggest concern now is getting my car back to normal running conditions and I am taking it into the dealership next Monday. I talk on the phone with them today and they said that it could be a bunch of different things going on with the tranny and its best for us to diagnose it when you bring it here so we can perform what is needed to repair your transmission.
When doing the drain & fill, did ya use Honda DW1 fluid ?
How was the AT fluid's level and how did the old fluid look & smell ?
So ya got a week to try cleaning the tranny's shift solenoids or replacing pressure switches. Worth a shot, along with another drain & fill, IMO.
Chances are that the dealership will charge you more for a diagnostic than what you could replace these parts for yourself. Check other posts !
3.2TLc I took it to my local shop to have the oil changed and trans changed so I dont have to worry about the disposal of the fluids. Although, I think if the car doesn't get any better within the next week I am going to take it to the Acura dealership for service.
Is it really that bad.....?
If it is, be prepared for the inevitable worse case scenario......especially when dealing with the dealership.
Best of luck, and may God bless you and your car.
Yes I know, but since this is a serious deal I want to make sure that it is done correctly and that if it continues to happen they will make it right before they return it.
To each his own choice, they'll attempt to make it right.....but it'll cost ya big !
xakura21 (03-14-2013)
Well in that case, go for the best !
Now are they also going to subsidize all the performance and appearance mods also ?
If so, we can help ya make a very good wish list !!!
Yes they have given me up to 20,000 to spend since my younger sister got a new car. The only catch is what ever I use from that 20,000 the less I will get when I want to buy a new car. Now they will pay for maintenance for the car, but any aftermarket part I put in that's not needed is put towards the 20,000. Keep in mind installation cost as well for the things I cant do myself. So please feel free to make me a list so that one I have had this transmission issue fixed, I can continue modding my car.
Hey 3.2TLc are you going to make a list in the order i should get them. I am going for performance next so lets start there then add what ever you think would be good to do after.
Yeah, top the list with a CL-S 6 speed stick as Mil Dave suggested. Next, go for the supercharger for the gusto !
And get the headers and cat back exhaust for a mean growl.
Do that, and then come back for some more !!!
To be honest i dont think a 6speed mt is for me. So supercharger kit with headers and exhausts. Whats the difference between a catback system and just regular mufflers?
So i took my car to the repair shop today and they said whats causing your cars shift problem is the two shift cylinders A & B. I am having those done along with a tune up and trans flush since the oil is burnt again.
Sounds like the mechanic is fleecing you. Ask for your old parts back. Either he just doesn't know the proper verbiage and he replacing your pressure switches which run bout 45 bucks each and you can easily replace alone. If not it could be the 2 solenoids which run like almost 200 each I believe and can also be easily seen to be replaced.
Is it bad that a trans flush is being done? My dad and the mechanic think its fine for it to be flushed. Worst case i bring it back to the mechanic and he makes it right.
When was the last time your fluid was burnt as you describe it? In all my expirience, burnt fluid = toasted trans. Transmission fluid under normal conditions will darken and loose lubrication as it ages, but NEVER should smell burnt. I have put 17,000 miles on my tl since i bought it, and have done 3 1x3s along the way. Never once was my fluid burnt, just a little orange. The only vehicles which Ive expierienced to have burnt smelling fluid only lasted a few more miles until either one or all the gears would give out.
There actually is a "Lock-up Shift Control Solenoid Valve A" and also an "A/T Pressure Control Solenoid Valve A/B Assembly" ....both of which are listed within the service manual.
Replacing these parts won't help much if the tranny fluid is showing distress in color and smell. Have the fluid analyzed for composition of material within it.
Alright. Thanks all for the continued support and help. My dad and i had a long talk this evening and decided that if i have to replace the transmission its not worth it. He said he got a quote today from a tech and it was 4k for new one installed but they said its not worth putting in a new trans since the car is 13 yrs old. It pissed me off when he called today because he told me that making this repair is a 50/50 chance of fixing the issue. So it wasnt a great day once i received that message. I will know tomorrow if the repair worked. I will keep you all up dated. Fingers crossed it worked.
jra8858 (03-12-2013)
![Cool](https://acurazine.com/forums/images/icons/icon6.gif)
Hey man, if ya take a car to any garage for a tranny issue .......be prepared for the worse case scenario, as you are at their mercy ! But, with a drain & fill along with a new filter and cleaning the solenoid valves .....may buy ya some time. Ya never really know for sure. Ol Mil gave ya the most cost effective long term solution for an ailing tranny diagnosed as bad. Cheaper than a new car payments.
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
Alright, it's Monday (3/11/13). Thanks all for the continued support and help. My dad and i had a long talk this evening and decided that if i have to replace the transmission its not worth it. He said he got a quote today from a tech and it was 4k for new one installed but they said its not worth putting in a new trans since the car is 13 yrs old. It pissed me off when he called today because he told me that making this repair is a 50/50 chance of fixing the issue. So it wasnt a great day once i received that message. I will know tomorrow if the repair worked. I will keep you all up dated. Fingers crossed it worked.
![Coo Coo](https://acurazine.com/forums/images/smilies/coocoo.gif)
A few days have past as it's now Friday (3/15/13) and we have yet to hear how your situation turned out. Please update with the verdict !
