Newbie say HI and has an emergency. Please help. Thanks!
My steering wheel is loose. Don't know how to explain it very well so here goes nothing:
Every time I turn the steering wheel, it seems that it shifts out of position. For example, if the steering wheel is straight and centered and I turn the steering wheel, sometimes I hear a crackling sort of noise and then the steering wheel is at 90 degree angle while the front wheels are straight. It constantly changes positions. Right now with the front wheels straight, the steering wheel is upside down.
I think it needs to be centered and tied down like the way technicians do after an alignment. It is loose so its constantly changing positions.
Does anyone know how I can tighten that bolt? Do I have to remove parts of the steering wheel? Anyone have a DIY for straightening the steering wheel.
Can I tighten the bolts on the steering wheel so it doesn't shift out of place? It seems like the guy who may have done the alignment, straightened the steering wheel (Aligned the steering wheel) and probably forgot to tighten the steering wheel properly in place. Don't know who did it.
Any help would be greatly appreciated. Any pictures or figures showing how to do it would be golden. I can't drive until I fix the steering wheel in place.
Thanks in advance!
Thanks in advance!
no accidents we need to know about?
they dont remove the steering wheel to straighten it- they adjust its position using the tie rod ends- same thing you adjust to fix the steering pull issues its in alignment for~
If your alignment came out on spec- meaning nothing is bent, the number were right on, then your tech left something loose!!
go back immedialty- have the car towed!!
I would not drive it like that!!!
in answer to question: you have to remove the airbag to get to the steering wheel nut
Try pulling on the wheel- if it doesnt have motion towards you its good
try it with car off and move steering wheel- should come to the ignition steering lock and stop- no movement..wont move until you put key in and turn on- then pull on wheel to release lock pressure
you may also have steering rack issues-
how is the fluid level and color- smells like burnt sugar?
sounds like a possible rack issue.
It seems that something came loose and the steering wheel won't stop from turn to turn. It just keeps on turning and I hear clicks. Seems that once the tires are turned all the way, the steering should lock in either direction, however, it is not. I'm assuming some bolt is loose.
No front end accidents.
Steering fluid look OK AND THE RACK LOOKS OK.
Previous owner was an anesthesiologist and always performed all services through Acura and always did everything that Acura told him so its probably been over maintained.
Is there a diy here on how to remove the airbag and/or steering wheel. I'm assuming that some nut/bolt in the steering column has come loose or the steering lock may have broken.
Could it be that rod that connects the steering to the rack (don't know the name) causing my symptoms of the steering wheel clicking and moving more after the wheels have been turned all the way to one direction?
with the car off and key out can you turn the steering wheel and not have the wheels turn?
With the key out car off: It will turn a little. I hear "click", "click", "click" and then with a quarter turn the steering wheel will lock and then it won't move in any direction. I have to put the key in to unlock it.
With the key in position 2, car off: The steering will will turn and again I hear it "click", "click", "click". Tires don't move, only the steering wheel moves but since now it is in position 2, the steering wheel does not lock.
PLEASE tell me its something simple, like a loose bolt or something.
Also With the car started: The steering wheel will turn normally to either side until it's done turning the wheels and then it will keep on turning and I hear the "click", "click", "click".
YES SIR! This is what it does:
#2 does the wheel keep turning and turning or does it go as far as #1 or do the wheels start turning.
With the key in position 2, car not started. Keeps on turning but the wheels won't turn. The steering wheel won't lock. All I hear are the clicks.
COTM Coordinator
Sounds like a spline either where the steering column meets the rack or the steering wheel mounts to the column (I dont think its the steering wheel to column)
Sounds like the steering was locked and when your tires turned while on the trailer it either broke something or wore some spline teeth out.
What parts or area would be suspect if your steering wheel is locked and great external pressure on the front 2 tires cause the tires to actually turn about 15 degrees? I suspect this is what occurred while I was towing the car.
Any ideas with this new info?
COTM Coordinator
Since whats broken/damaged is already broken/damaged i would have someone turn the wheel until it starts clicking and try to locate the source of the clicking. I think its either going to be where the column meets the rack, which is in the engine compartment just forward of the fire wall, or where the steering wheel mounts to the column, which would be right behind the airbag.
COTM Coordinator
I would remove the airbag to visually check if its the wheel to column spline. To remove the airbag you should first disconnect the battery (get your radio codes first and write down your presets) On the bottom side of the airbag there is a plastic cover that you can remove to access the connectors. Pop the cover off and disconnect the airbag connector. There are going to be 4 torx screws that need to be removed in order for you to remove the airbag. If I remember correctly, they are behind the 4 spokes of the steering wheel. Once you remove the screws pull the airbag toward you. This will reveal the mount bolt/nut (i forget what it is) it should be 14mm or 17mm. Break that loose and remove it and you should be able to see the splines.
COTM Coordinator
There isnt any gears, but the spline does have the cogs that a gear would have (just so you can get a better mental picture) Its made of metal not plastic and if the splines on the wheel are broken you would need to buy a new wheel, if the splines on the column are broken well..... then a new column would be in order.
COTM Coordinator
You should be able to keep the same ignition. And dont worry about your lack of car knowledge. Spend a few months in this forum and you will be an Acura TL mechanic..... unlicensed of course.
Let us know how it turns out.
COTM Coordinator
If its the wheel, go with a 02-03 type s wheel. You will like it much better then the premium model wheels.
Always Working In
Looking at the service manual there are two torx screws on either side just below the headlight and the wiper handles on either side after you remove the upper and lower steering covers. The top pops loose by hand by pulling straight up, the lower has two screws I think.. The screws are sized T30 torx bit. There is a 2 pin connector to unplug. Should be yellow in color. All SRS connectors are yellow in color. Once airbag is removed unplug radio switch and cruise control switch connectors. Loosen the bolt in the center of the wheel.
After that according to the manual you will need a steering wheel puller to free the wheel from the column.
These are directions straight from the manual. I've never done this myself so maybe someone can say for sure if you need a puller or if there's another way of doing this.
COTM Coordinator
Another way to remove the wheel without having the puller is to loosen the mounting bolt until there is about a 1/4 inch of gap between the head of the bolt and the surface that it mates to. Grab the wheel with two hands and pull while rocking side to side slightly. Leaving the bolt in place keeps the wheel from coming off and smacking you in the face since you are pulling towards you. I know this is an unconventional way of removing the wheel, but i guarantee you that it works.
Any steering wheel from the TL will work, Its the airbags that will not work properly. 99-01 airbags are interchangeable and 02-03 airbags are interchangeable.
He wasnt trying to remove the wheel, but rather check for any signs of damage where the wheel meets the column. Either way, good post.
look at the end travel stops for the steering rack before digging into the wheel
I stay with my original plan- take to to a pro for diagnosis
In the air they can see a lot more than you can on the ground
COTM Coordinator
It will take him 15 mins to check the steering wheel and he will have to wait until at least tomorrow to have it looked at by a mechanic. At least he will be able to eliminate that as a problem, or find out it is the problem.
Hopefully I can take a look today and then report back. I had also bought cargo insurance from uhaul. Will call them today and see if they will cover it. Hope I don't get the runaround. Trailer and towing rental coverage Safetow® http://www.uhaul.com/protection/
What do you think? Will they cover it?
UPDATE: Got on my hands and knees and had someone to turn the steering all the way and then some to make it click. It is definitely coming from the bottom end. Couldn't see anything because the car is so low, however, I could also see and feel the tire vibrate with the click. Definitely something from the lower section. I asked a mechanic to come over and check it out so I hope he comes soon and tells me something.
