New Rotors
Cruiser
New Rotors
I'm in the process of getting some new rotors on my 2001 TL. Has anyone put the pro stops on their car? If so, how are they and how much you pay for them?
Cruiser
can I get some feedback on the aftermarket rotors. I'm currently looking at the brembos, rotora, irotor and pro stops. If you bought any of these I would like to hear they are working for you.
i have the irotors and recomend them check out the group buy on htm in the black market section of this forum. they are very nice build quality and they have (so far) resisted warping. i would also highly recomend the EBC Green Stuff Pads over the axxis pads. i am going to get rid or the axxis pads after only 2000 miles. they produce way too much brake dust.
2003 SSM TLS
drilled & slotted rotors make a hugh difference over stock piece of crap rotors. No matter how hard you you repeatedly use them and get them hot, the rotors cool quickly and don't warp. You'll really enjoy them. What pads did you end up with??? I used the Axxis, but a lot of TLers are using the EBC green stuff. I interested to know which are better???
Cruiser
I just discovered this group buy web site and there is a group buy set up for Brembo slotted rotors. Has anyone been on this site? http://www.groupbuycenter.com/default.aspx
dayum no slotted rotors for 2001 TL :rocketwho
2003 SSM TLS
Hey antlive, check out the irotors on ebay. They have pretty good prices for the 2001 TL. Not quite group buy, but their not that high for drilled/slotted rotors.
and for antlive's question...... yea cross drilled rotors tend to crack, but the irotors dont have as many holes in them and more material around the cooling vanes in the center which should help reduce/eliminate the cracking issue. and when rotors do crack its usually just surface cracks. it doesnt make the car undriveable. and also by time they do get to that point its usually time for new rotors any way because of age and wear (because you cant have them turned)
I have the EBC green stuff pads along with EBC dimpled and slotted rotors on my CRX and they work great! I plan to put them on the TL as soon as it needs pads.
On a side note, I know the NSX calipers will fit on the TL, but I'm unsure on what rotors to use to finish the swap. Has anyone here done this?
Originally Posted by antlive
they do have a good price, $249 for 4 rotors. I really don't want the drilled holes though I've heard they crack after a while.
If you only want slotted, I got all four Rotora slotted rotors for $302 (free shipping) at www.streetbeatcustomes.com. I used the Axxis Deluxe Plus pads. Just installed the last Saturday so I have not really tested them out yet.
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
