New Left side bearing and still humming!!
So i replace the left front and the rear wheel bearing and its a lot quieter. But its still humming. The noise goes away when i make a right turn putting all the weight on the left side. What can it be BAD parts maybe?? Should i take it off and return the parts for a new one? I purchase them both at Oreilly Auto Parts. But i did notice the sway bar on the left rear is is apart where it connected (picture below)
Tires are Brand new. Im pretty sure its the left side, because when you put the weight onto the left side the humming goes away and when you put the weight on the right side the humming is still there. Wen i say putting the weight on a certain side, im doing it buy switching lane really sharp shifting the weight. Its an old trick i use to do to figure what side the bearing is bad on.
The sway bar end link do they just sell that part? or do i have to buy a whole new sway bar?
But if im going straight the sway bar is out of play and the humming noise is present.
+2... The only way you're going to know for sure is with a mechanic's stethoscope. Even better if you have access to a hoist and can run it in the air. I've been absolutely sure, and absolutely wrong, using the swerve method you described. It is still a good place to start, and works 90+% of the time. It's pretty rare for new tires to be noisey.
rockyboy
01-25-2016 06:00 PM
sockr1
10-01-2015 01:31 AM
