New Brakes are on
Chapter Leader (Southeast Region)
plus I got them for a good price
follow the makers bedding instructions- it takes several times to get the pads and rotors fully mated to each other for 100% braking
did you do the ABS test? not really good to do on brand new brakes,,but..
the test per acura `after line has been opened`-to replace caliper as example
from 45mph do 2 ABS active stops
will probably need water or gravel to do this, and swerving back and forth wildly to lose traction- so the abs is forced to operate and pump against your foot
what happens is air manages to get into the abs controller and wont show itself in the normal bleed
Do the first stop to full stop and accellerate to 45,
repeat full effort abs active stop
if the 2nd time had a firmer/stiffer feel to the pedal = there was air
bleed system again and all is good
Next time you have the wheels off- paint the center of the rotors, may have to touch up th edges too
Use bbq 1200 degree paint
If you like the wheels, thats all that matters
I have not done the ABS test yet because I wanted to make sure they brake in first. Already did the manufacturs bed in procedure. I should not have to paint the center of the rotors because they are zinc plated to prevent rust. we will see how well it holds up but according to other people it has been. Plus my car is parked in a garage evey night so the only time it is outside is at work and school.
The Zinc Plate wont hold up anything.. A couple of Heats and the Zinc Plate will fall off, My 3GDs where Zinc Plated didnt last a full beat up.
Thats why I re-painted them they still have the paint.
Just cover the Hats:
Notice how they have the Zinc Plate (Golden Color).
The E-Brake Drums is what Rusts the Most..
I Recommend for the Base:
Then:
For the Glossy Effect!
Installed:
Old Pic hehehe still with 1-pot.
Sorry if the Pics show up too Big, I re-sized them but dunno if its Displayed right.
Then:
Installed:
It may take several times of bedding and 500 miles normal use to get the pads and rotors fully conditioned
When the crosshatch is worn off the rotors = now they are real brakes!
usually the 1st bedding just gets out the excess resins,, used in making the pads.
Now you want to wear all the hills and valleys into each other for full contact
Are you on SS brake lines yet? used DOT4 or DOT5.1 fluid?
(NEVER DOT 5.0 = death to system)
DOT 5 is a NO GO.
DOT 5.1 is Compatible with Old DOTs 3/4 Systems with an Even Higher Boiling Point.
SS Lines will Improve feel with your new Legend Calipers Stephen! I recommend "Goodridge" Lines as they come with the BREMBO Gran Turismo BBK...
. Guess I'll get a second car at that time and work on it also
Yeah black chrome. Trust me I hated chrome wheels always liked polished silver wheels. I had cls wheels for the longest time then bent two of them
so I got the 17"black chrome tsx aspec wheels but got a flat and when they repaired it they scratched the heck out of the wheel so I had them replace it. I needed new tires and found the 18s with tires and bought them and sold the old ones
SS lines are exactly what you want for those sudden massive 80-20mph decellerations,
the average driver encounters all too often
rubber lines expand under pressure,,losing pressure to the caliper piston = loss of braking torque
worse when the lines are hot from extensive use (fun runs) of course
Go open your hood and watch the line as helper pushes brake pedal- simulate bleeding line
Observe the expansion of the line- sitting there cold and not at max foot pressure
next, choose the vendor for lines! mrheeltoe and excelerate are good sources for info and products
note: your new brakes will continue to get better and better with use
the removal of rotor cross hatch is where the final bedding starts to happen
go do it again--with a good transfer layer of material after they are hot-hot
then 15 minutes cooling drive on the freeway
go do it again--with a good transfer layer of material after they are hoti-hot
It is hard to tell because I swapped the rotors and the pads at the same time. what I can say is my braking has greatly improved over OEM. Before when I would hit the brakes at 80+ i relly had none and the steering wheel would shake so bad I thought it was going to fall off
Yep same here!
I did my Legend Caliper with new Rotors + Yellow Stuffs...
What I can tell you is that Heavy Brake Somewhat Improved but the Real Gain was Brake Feel thats the amount of feel once you start light braking that was non-existant with the OEM Caliper you where braking or Not.
Yep same here!
OP, I love the wheels and the brakes look great behind them
. I too have the brakemotive products and am extremely happy with them.
I opted not to paint the hats on the rotors because I have heard that the zinc on these is really durable, so you're not alone. If the need arises, it can be done.
Just one thing I was wondering....if you are getting a slight screeching/whining when applying the brakes lightly during verrry slow stops? I am but haven't heard of a similar problem. Not enough to make me love the product any less...just curious if you have had a similar issue.
the rears are the same caliper as the TL and most other hondas of the 70s-2000s
no need to replace them unless you have an issue with crud in lines
then get TL rears
fronts are for a 1995 legend LS-C (coupe)
those have the piston sizes closest together -thats what we want
see anyone from rockauto to kragen/oreillys
I used the raybestos numbers frc10627 and frc10628
those come with a new mounting bracket--we grab the bolts and clips off it and throw the bracket back in the box --it wont fit the TL no matter how much it appears to-
I tried just to find out why!
others found the numbers for just the bare caliper--no bracket,,I am guessing they bought new hardware as a kit, or used the old stuff (bad idea-brake hardware should be replaced every pad change along with a fluid flush-especially on an upgrade like this)
the parts store is happy to get TL calipers back as the cores--a much larger market for selling them,, than some crazy fits only a few older years/models cars
Say nothing= just turn them in. calipers is all they care about being in the box,,
empty of fluid of course!! and in a ziplock never hurt
then get TL rears
The part numbers are FRC10627 and FRC10628.
Dont forget to Flush the System by the Book!
Also if you do SS Lines in all 4 Calipers you will feel an even better Upgrade on the Brakes.
I have been driving on the original 1 piston calipers for the past week or so and I must say there is quite a difference. I went to take my car in for an alignment and they called me and said my breaks were leaking a little ( the legend two piston calipers). I asked them if they could fix and they said not really since you did not have it done here. I went to pick up the car and they said just tighten it so I took it home looked under neath and it was leaking. So I went to tighten it and it was stripped out. I hit the brakes and fluid was pouring out. I had to swap the original calipers back on since I drive it everyday. When I took it in for the alignment I am pretty sure they messed with it and stripped it out since I had been driving it for a month prior and it was not leaking, not to mention when I was changing calipers I noticed it had different washers than the ones I put on. I called the manufacture and they sent me replacements and I sent them The messed up ones and will be putting the 2 POT back in next week since I repainted them this morning
Why would they mess up with brakes for an aligment?
You used the Original Banjo screw? or did you use an Aftermarket with SS lines? cuz sometimes they use a shorter banjo screw on some Aftermarket SS lines (Including my Goodridge Kit) I just re-used the OEM Banjo screw and used the Goodridge washers been fine for almost 2 years now?
Must be nice lol, I'm still rocking the stockies. How much would you be lookinf for the wheels?
I get new wheels and tires everytime I need new tires and sell te old ones
