Neuspeed strut bar not that easy :(
I've been reading how easy it is to install the neuspeed strut bar. Some say it can be done in 10 minutes. I guess not mine. With the car level to the ground, the strut bar was almost 1/2 inch too long. I had to jack my car up on both front sides. Way up!!! It still would not want to slide into the screw studs. So I waited about 10 minutes. I thought maybe it takes some time for the car body to flex a little bit. Well, it worked. The bar finally bore through the studs on both sides. Sometimes I amaze myself, hehehe.
I got my ABP TL-S 2 months ago. Only have Comptech sways and the strut bar so far. These two mods make the handling and steering so much better than stock. You'd think with a type-s they would have good handling off the lot. Guess not.
I ordered the strut bar 2 days ago and it was at my doorsteps today. Thanks Tim...
Re: Neuspeed strut bar not that easy :(
btw, Welcome to the forums!
I put the Neuspeed upper strut bar on my TL-S a couple of weeks after I bought it. Went on with very little effort and did not have to jack up the car at all. I have not replaced the springs.
Just added the Comptech sway bars a couple of weeks ago. Waiting for the RES now...
my car is lowered on h&r's and i just put on the tie bar today and i had to jack up the car on both sides to make it fit. just a theory, but maybe the weather has something to do with it. metal in the car frame might flex due to temp.
I also only have the sways with the fat tires and wheels.
I did the install (of the tie bar) on a very flat surface, and it slid on when I loosened the 14- and 12-mm nuts on the strut and existing (factory) bar.
Originally posted by TypeSDragon
Nope! You will need to get an alignment only when you lower your car.
Originally posted by yee
thanks...now would the handling be much improve if all you do is add sway bar? and not lowering your car??
ITSJESTER
17
12-06-2018 03:29 AM
lanechanger
10-13-2015 11:56 AM
