need spark plugs for 02 tl-s
![Arrow](https://acurazine.com/forums/images/icons/icon2.gif)
im in need of some new spark plugs for my 02 tl-s. ive searched and found mixed info regarding ngk ik16's vs. ik20's (i think those are the part #'s). well i have intake, headers, and some other mods. Would it be better to go with the colder ik20's or no?
also what were the part #s for the denso iridiums? thanks guys!
On the way!
IK16 and IK20 are Denso part numbers. Stock is the IK16, and the IK20 is the colder plug.
For NGK part numbers, the part # is ZFR5FIX-11 (TL-S application) or BKR6EIX-11 (NSX application/colder plug). I think the 4th digit is the heat range.
I'm running ZFR5FIX-11. I think either plug would be fine - even on a TL-S with mods.
The part numbers are in the owners manual.
NGK's are installed at the factory and the P/N on my 2002 TL type S are PZFR6E-11. These are platinum tipped. The Iridiums have a 6 in the p/n as well (I believe I got that from the NGK site)
I dont know what these other p/n's you speak of are, probably the iridiums but for the -p's. There is a difference between tl-p and -s, but have heard of folks using either-or and being ok. The difference in the plugs is a difference in heat dissipation. Reach, thread, etc are the same.
I've got pics of my plug change but have been too la - I mean busy - to post them.
Originally Posted by acrite
off the subject, i got my iridiums for only 24$.
the guy only charged me for 4 plugs instead of 6 =)
That was still cheaper than the platinum NGK's.
i had densos. great plugs, but they dont last near as long as the NGK
On the way!
Originally Posted by 2002AcuraTL
So which plugs work best for a TL-P? I understand they both can be used but is there any difference when using the lower heat vs. higher heat versions?
Ok - end all.
According to page 242 of the TL owners manual:
Premium Model
NGK: PZFR5F-11
DENSO: PKJ16CR-L11
spark plug gap: .04 in (1.1mm)
Type S
NGK: PZFR6E-11
DENSO: PKJ20CR-M11
spark plug gap 0.04in (1.1mm)
I know the PZFR6E-11 is a "cool" plug since it dissipates heat to the head more so than the PZFR5F-11. PZFR6E-11 were installed on my TL-s at the factory. No mods.
I think you can use both plugs and be just fine. They cost about the same anyway. You might have a better time finding the '5F-11's in stock at autostores since I think they are used in other Honda V6 engines (not sure tho).
Originally Posted by fsttyms1
i had densos. great plugs, but they dont last near as long as the NGK ![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
werent you running iridium tipped plugs? I remember you mentioning that in an earlier forum. Just curious and looking for an update.
Awesome SPL1011, and thanks. Someone actually went to the manual! DoH I wish I had thought of that!
Now, to throw a monkey wrench here, is the
NGK PZFR5F-11 the same as the NGK ZFR5FIX-11?? Aside from a "P" in front of the OEM listing, and a "IX" at the end of the other NGK part number, does anyone know if these are the same?
![rtfm](https://acurazine.com/forums/images/smilies/rtfm.gif)
Originally Posted by spl1011
Ok - end all.
Premium Model
NGK: PZFR5F-11
DENSO: PKJ16CR-L11
Type S
NGK: PZFR6E-11
DENSO: PKJ20CR-M11
Premium Model
NGK: PZFR5F-11
DENSO: PKJ16CR-L11
Type S
NGK: PZFR6E-11
DENSO: PKJ20CR-M11
Originally Posted by PiMpiN wHITe Cl-S
difference is the PZFR5F-11 is the premium model as the ZFR5FIX-11 is the iridium model.
Which is preferred, the platinum or iridium, and why?
Well, I had 68k on my stock platinums when I changed them they looked really good. Clean, no pitting or noticeable electrode wear. Gaps were still a tight .040".
Iridiums are supposed to have better resistance to wear (4 times harder than platinum). They also tend to cost more. Don't look for a power improvement between NGK plats' or iridiums - you wont find one.
I guess it comes down to personal preference. For me, there was no value added and the money I saved paid for the anti-sieze stuff. I stuck with platinums. In my professional opinion, there really is no difference in our cars.
acuratl26
04-23-2020 07:30 PM
ITSJESTER
17
12-06-2018 02:29 AM
MetalGearTypeS
08-29-2016 08:28 PM
Joe Avesyan
09-29-2015 03:57 PM
