Need someones help: headlight aiming
Old Jul 4, 2004 | 08:58 AM
Darkshear's Avatar
l33t
Guys, now that the front end is much lower than it was, and its raked like crazy, ive noticed the beam pattern lower as well. so i need to adjust the aim of the headlights, but i need something to compare to. could one of the 99-01 guys park 6 feet from a wall and measure the distance fromt he ground to the very top of the beam??
i would greatly appreciate it!!!!
-kalon
Old Jul 4, 2004 | 08:47 PM
jpadilla's Avatar
i could also use this info ....
Old Jul 5, 2004 | 12:02 AM
edgalang's Avatar
Purchased: April 28, 2001
-kalon
What you need to do is drive in the fast lane of a freeway with concrete barriers and make sure the left headlight beam pattern NEVER tilts up. Then...go home and match the right side with the left. Although you are still technically set too high, at least you are NOT blinding on comming traffic. BTW...the proper angle is 15 degrees.
Old Jul 5, 2004 | 08:33 AM
keeena's Avatar
Darkshear - Here you go...
How to aim headlights
Old Jul 5, 2004 | 08:52 AM
fsttyms1's Avatar
just park from a wall at night and adjust them higher (the symbol on the cover is backwards as to which direction you are supposed to turn them) and raise them a little go driving, if you arent happy do it again. if you start really getting flashed they may be a little to high.
Jul 16, 2017 07:33 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
rockyboy
Sep 29, 2015 12:05 AM
AmplifiedDetails
Sep 24, 2015 02:55 PM
