need some help with LED puddlelights and door handle lights
hi so i wired everything the puddlelights and doorhandle lights to the dome light wires for a 02 tls i also have a 40 led panel for my domelights. the problem is the lights go off with when i lock the car and on when i unlock. but when i lock it again it turns off and would turn back on randomly. i dont know whats going on.. whereas if i put back a halogen lamp in it doesnt seem to do that as much..
is it maybe i have too many leds running thats screwing up the relays or something?? im not very good with electronics stuff.
i also read that i can run the wires to the passenger fuse box theres two wires and also the drivers side. if i did that would my lights go on like how its wired to the domelights? or is it only when i open the doors and close the doors they turn on?? thanks for the help
I have somewhat a similar problem for my dome lights. My domelights won't autodim, causing my LED's to stay on. I think it has to do with a relay located in the passenger fuse box. If you find the answer, please let us know as I'd also like to have the problem fixed. Good luck.
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
handsom-hustla
Nov 13, 2015 05:04 PM
drewdeezy03
Sep 3, 2015 08:04 PM
