Need some help or any pics would be appreciated!
The New 3 Series Coupe
I know this topic might have been up for quite a few times already; however, I just got my kit and tried to do a search on this and came back with insufficient infoz.
Here are some questions that needs to be solved to get myself prepared before I actually get down into it in this weekend...
I wanna install the WW kit on my own... kinda wanna get the "fun" out of it by installing it myself but was wondering other than the adhesive tape, are there anything else we need for the front? Bolts perhaps? If bolts, where do I need them? By the holes where the mudd flaps used to use?
Do I need any screws in the center of the kit?...
When I got my WW kit it came with about 14 self taping screws. I put 4 in front two in the center and one on each side in the wheel well, I put two under each side skirt,and two in the back. I'm assuming you already had it painted better make sure you got a good paint job because mine was done cheap and they didn't add the flex stuff to the paint so when I scrape and the kit flexs paint does'nt chip. I have to drop off the kit this week for the third time since I got the kit to get painted im furious, and if you have an aftermarket exhaust system make sure you re-adjust the tips so they stick out a little because the heat will cause the paint to flake off and trust me you dont want to go thru the stuff I did. I kick myself in the ass every day for not getting the OEM kit.
OEM paint is the best
Ponsey_Scheme
10-23-2015 09:16 PM
