Need some help
Old Oct 13, 2009 | 04:14 PM
TLGOD84's Avatar
Registered Member
Need some help
Hey everyone, I have a 2003 Acura TL. My car has been sitting out on my drive way for the past 4 months now because I dont have money for a new transmission. So I turn it on sometimes and I always hear the engine reving up and down. Why is this and what can I do to fix it?????
Here is a video
Old Oct 13, 2009 | 04:29 PM
fsttyms1's Avatar
Thats a stuck/dirty IACV. It would most likely clear it self up once you started driving. Take it off and clean it.
Old Oct 13, 2009 | 08:08 PM
01tl4tl's Avatar
throw a can of seafoam or stabil in the gas tank and run for 10 minutes
That will keep the gas from going bad and gunking everything up
Its harder on the engine to be run for 5 minutes than to let it sit unused
The oil needs to get fully warmed and the exhaust, but short cold run only add to the problem
You can shoot deep creep into each cylinder, or do a seafoam `fog to stall`- then it will be ready to go when you are
Old Oct 14, 2009 | 08:21 AM
TLGOD84's Avatar
Registered Member
OK I put Stabil in my car. How do I clean the IACV?
Old Oct 14, 2009 | 09:04 AM
Rockstar21's Avatar
The Dumb One
my cars do that when the vacum hose is pulled off also.. possibly a leak?
but check what the others said first...
Old Oct 14, 2009 | 10:35 AM
01tl4tl's Avatar
the iacv is located on the bottem of the TB assembly
remove unit from intake manifold and clean to fix
Dont bother till its ready to run again, quit starting it and getting more crud there!
run engine 10 minutes after stabil added to tank so it gets into things as needed
