Need to know ASAP
Old 02-12-2004, 08:49 PM
Need to know ASAP
Can someone tell me if this size will fit 2002 Acura TL-S
Michelin Pilot HX MXM4 225-55-R17 V-rates
Old 02-12-2004, 09:12 PM
StanMan's Avatar
fit how???
codelogic's Avatar
factory tiresize on the 02 tl-s was P215/50/R17
if you go to 225/55/R17 your speedometer is going to be off a little bit, because the tire is a little wider and your profile is a little bigger, therefore your total circumfrence of the 225/55/17 is: 123.75in (full rotation of the tire)
the 215/50/17 overall is: 107.50 in
so if you put those 225/55/17 tires on the car, your speedo might say 40 when youre really going 45..or vice versa, it's a little late for me to do THAT much math right now -- hope this helps!
Old 02-12-2004, 09:21 PM
But they will fit mu wheel?
Will I have any troubles driving on them?
My tires are bad and the guy is asking not bad price for these, I think...
They have only 2000K on them 4 for $200
Old 02-12-2004, 09:33 PM
njtls's Avatar
its gonna lookweird...and you could have rubbing issues...i eman wider and higher profile..its not practical....you'll accelerate slower...and probably worsen your gas milage
Old 02-12-2004, 10:26 PM
is the Mighty Favog
Tom Blasing's Avatar
Not sure if it will fit the wheel but a +1 size would be a 225/45R-18 but you did say you're using the factory rim I take it.
With the size you asked about, just think, there is going to be aspect ratio measuring 55% of 225mm = 123.75mm. Where as the factory tire has a ratio of 50% of 215mm=107.5mm. So the tire you're asking about will be taller overall and throw off the speedo as said already. I'm guessing that'll be about a 13% difference.
Old 02-12-2004, 10:58 PM
yield2s's Avatar
I'd say go for it, I would. it'll prob fill some of that awefull wheel gap.
Old 02-13-2004, 01:55 AM
Vicman17's Avatar
It's the same cr*ppy tires as the stock Michelins, only on a different size. You will have the same bubbling problems and inferior traction and noisy ride as the stock one (probably worse).
Save your dough for a newer and better set of tires. Can't wait to get rid of mine and jump into better ones like Dunlops or Sumitomos.
Old 02-13-2004, 09:24 AM
Turboara's Avatar
I think that is too wide of a tire for the stock wheel
Old 02-13-2004, 11:54 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
the 225 will fit but the sidewall will be taller throwing your speedo off.
Old 02-13-2004, 12:05 PM
Honda+Blue=My garage
pmptx's Avatar
I have 235s on my stock rims. The height may be your problem. width is ok.
Old 02-13-2004, 12:57 PM
TypeSDriver's Avatar
Your sidewall is going to be .7 inches larger than stock. Also, when your speedometer is reading 60 mph you'll actually be traveling at 63 mph. I wouldn't do it man, it's going to look really odd. Try to find some stock size tires. You can get the Sumitomo HTR+ from tirerack for approx. $335 shipped to you. They will be the correct size and are excellent tires. Do yourself a favor and spend the extra $135, you'll be glad that you did.
Old 02-13-2004, 06:06 PM
Thanks guys for the info.
F..k the stock tires... I am going with Sumitomo
njresendez
3G TL Photograph Gallery
09-21-2015 06:32 PM
Skirmich
09-15-2015 06:41 PM
Billu99tl
09-13-2015 11:30 AM
Quick Reply: Need to know ASAP
