Need help to remove the side under spoiler!!!!!!!!!
Old Aug 26, 2004 | 07:54 PM
Need HELP!!!!!!!!!!!!!!!!!!!!!!!!!!
Oh man, I tried everything following the instruction to remove the old side under spoiler, it didn't move a bit.
Can someone tell me how to remove it? Need help now!
Old Aug 26, 2004 | 09:49 PM
Sic TL-S's Avatar
I had a hard time on my 03 TLS as well. Push the side of the skirt closest to the rear wheel towards the front of the car. Dont put too much force on it, but it will move, then just pull the skirt towards you and it should come off. Anyone feel free to correct me if I am wrong.
Old Aug 26, 2004 | 09:50 PM
Sic TL-S's Avatar
by the way, it helps to have the doors open, so you have access to the skirt more easily
Old Aug 26, 2004 | 09:52 PM
NYZGREATST's Avatar
Sig Rho's Finest
i unscrwed it from the bottom, pulled out the pins and then started at the rear of the vehicle and pulled hard eunf and the stock sides popped out.
Old Aug 26, 2004 | 11:53 PM
thanks everyone, I got it, I end up using a bar to pull it out. now it's only the front left, well, I'll take it apart tomorrow, I'm really tired now.
Old Aug 27, 2004 | 12:06 AM
Pure Adrenaline's Avatar
Dragging knees in
The best way to do it --
for example, on the passenger side -- sit down next to the car facing the back of the car. Put your right foot up against the tire, use both hands to grab onto the side end of the skirt, and pull it toward you (and toward the front of the car) as hard as you can. You won't break anything. You'll hear a loud pop and it'll come off. 5 seconds. It requires A LOT of force, but you're not going to break anything unless you are Ahnold.
Good luck.
Old Aug 27, 2004 | 02:33 PM
Mongolian's Avatar
Good luck.
exact same method i used. took a bit of force. don't hold back! you won't break anything... unless you are ahnold...
mugen_kid
Nov 13, 2015 10:38 PM
nanos
Nov 12, 2015 08:41 PM
01CLOwner
Oct 9, 2015 01:07 PM
EE4Life
Sep 11, 2015 10:13 PM
Sep 4, 2015 08:03 AM
