NEED HELP QUICK - Engine overheated...what to look for
The fan won't turn on in front of the radiator. The condensor fan works fine, just not the other one.
OK, I've checked the following:
Fuses - under hood and in driver's side fuse panel - all ok
Relays - swapped one with another - all fine
Everything looks good. What else could it be? Any way to test if the motor is shot?
Thanks,
Neil
Thanks,
Neil
Unplug the fan and run 12 volts to it, one the "hot" and the other a ground. It should run. Normally a 12V current goes to a relay in the water jacket somewhere and when 195F ( or whatever) is reached the current is sent on to the fan. I've seen guys hook a test light to the output side and 12V to the input side of a relay and then dunk it in a pot of water on the stove with a thermometer in there to check for correct function! Good luck!
Yep. If the fuses and relays are good, then the next two things to check are the fan motor itself and the sending unit. If the motor is seized it won't turn even if the relays are sending it juice. And if the sending unit is shot, the fan doesn't ever get a signal to turn on because the threshold criteria is met. Chuck has the right idea.
Thanks Chuck and Pianoman,
It's amazing how much you rely on this board for answers and don't realize all the resources you have right under your nose.
Well I decided to pull the Helms manual
which I've had for several years....and used before
Ran through a bunch of diagnostics and low and behold it tells me it's what I thought.
Stealer wanted $46 for it. PepBoys wants $30. Looks like it's off to PepBoys to fix my ride.
Really can't wait around for the Mugen one so maybe next time. BTW, car has 60K+ on it.
Thanks all for your help.
Neil
Neil
Neil
Neil
blxmjx (from a-cl.com) can get it for you i believe, contact him about it. might as well get some performance out of it.
before you get the entire fan relaced make sure it is indeed the fan, I had the same problem... takje a wire and rig it in the swith, put one end in one outlet and the other in the other outlet, this will rig it so it gets continuous power, if the fan comes on, then the fan is not the culprit....
Possible causes of engine overheating:
1. Lack of water/coolant in the radiator system
2. Thermostat is fucked
3. Fans do not work (variety of reasons)
I hope you get that shit fixed and hope you caught the overheat problem before it did any real damage to the engine (i.e ruined any of the gaskets, etc.)
Well let's analyze....
1 - Fluid level does not effect the fans ability to turn on or off
2 - The thermostat does not effect the fans ability to turn on or off
3 - Already tested the fan, relay, fuses
Read my last post, I ran through the diagnostics in the Helms manual and everything is ok, except the radiator fan switch. The switch is not part of the fan, as shown by the picture about. It sits right next to the inlet/outlet for the radiator fluid.
I just hope you didn't blow a head gasket.... mine overheated after my accident due to a slight puncture in the radiator, and I ended up having to replace the gasket.... pain in the ass!
and congrats for doing it yourself! you're the man!
SSTS
holy thread revival
there is a sensor for the dash guage
and a fan temp sensor which operates the driver side fan based on need
see the many current threads on same subject,
90% of the time if your driver fan doesnt come on, or runs for more than 2 to several minutes after engine shutdown, you need a fan temp sensor
1999s at thermostat
2000+ located passenger lower corner of radiator-
has 1 wire to it and it screws in
price has gone up 10-15$ to ~45, since 2004 when this thread was active
1999s at thermostat
I know...bringing up an old thread again...for someone who is a beginner (i can change the headlights out no problem -thats as far as my knowledge goes) how hard is this fix? could someone take some pics of the entire engine bay and circle where it is? I ordered the part already...from rockauto
How hard? Depends on time more than difficulty..
If you wanna make you life easier remove Intake Tube.
If you wanna do it the hard way dont remove it.
Disconnect the Sensor
> Remove Sensor with Same Size ratch or Key
> Some A/F will leak (About the quantity inside the Top Rubber hose so Have A/F Ready to refill)
> Install new Sensor with some liquid gasket
> Plug Sensor
> Re-Install Intake Tube (Optional)
> Refill A/F
> Done.
> Plug Sensor
> Refill A/F
> Done.
Yeah man, just fix it now. The weather will heat up and so will your motor, those sensor switches are critical to maintaining a safe operating temp. It's not worth taking the risk of overheating and blowing a head gasket......big bucks !!!!!
Rob144
Sep 21, 2015 08:18 AM
