Need Help Now Installing Back Kit
for an 02?
the large clips go between the holes(slip the clip in from the inside)...w/ the flat piece stiking on the outside...I needed to use a flat screwdriver to make the hole a little bigger to fit easier
the side holes required drilling (at least I had to)...to do that I took out my rear tire, again the small clips goes between the fender w/ the smaller hole on the inside for tightening...
hope this helps.
hope this helps.
IIDXholic
10-08-2015 07:53 AM
nuldabz
09-03-2015 05:49 PM
