Need help locating PGM-FI Relay
Old Apr 20, 2015 | 08:26 PM
Mr Exlax's Avatar
I've searched for about 30 minutes. I think that's what's wrong with my car. I need to find out where this thing is cause I can't afford to miss a day on my new job. Somebody please let me know just a relative area and possibly how to replace it.
Old Apr 20, 2015 | 08:41 PM
Skirmich's Avatar
What exactly are you trying to do?
The TL doesn't have a F/I Relay, The ECU controls the F/I System.
Old Apr 20, 2015 | 08:47 PM
Mr Exlax's Avatar
It's doing the thing where it cranks but won't start up and it dies while driving. My key emblem flashes and then stops. Oh and the car cranks back up after waiting like 20 minutes. It won't start back up this time. I'm supposed to replace or repair some relay right? I don't have the time to repair so I gotta buy one and replace it.
2002 TL Type S
Old Apr 20, 2015 | 08:48 PM
01acls's Avatar
Above your right knee behind the lower panel if you were sitting in the driver's seat.
Old Apr 20, 2015 | 08:50 PM
Mr Exlax's Avatar
Thanks! Do I need to unscrew some stuff or do I just unhook and like snap something off or anything?
Old Apr 20, 2015 | 08:51 PM
Skirmich's Avatar
There are so few Relays in the TL and None of them are to Control the F/I System, The TL Ignition System is fully Electronic and the ECU is in charge of the F/I Operation as well as Ignition.
There are some people affected by some "Heat Soak Issue" in their Fuel Regulator at the Engine. You should look into that! It affected some 00-02 models.
If you are in real desperate need for your car to run ASAP go to a Dealership and Stop Guessing.
Old Apr 20, 2015 | 08:57 PM
01acls's Avatar
Take the philips screw out at the drivers side fuse panel. Open the drivers door all the way out, on the outside by the check strap.
Once thats out just pull the lower drivers panel off by pulling towards the seat.
Skirmich's Avatar
Again there are NO RELAYS to Control the F/I System.
I think what your looking for is for the "Main Fuel Pump Relay" which is in the Manual as "PGM-FI Relay".
And unless you already diagnosed that your fuel pump is not working, That relay is fine.
Old Apr 20, 2015 | 08:59 PM
Mr Exlax's Avatar
I saw that name too. That's gotta be it.
Old Apr 20, 2015 | 09:00 PM
Mr Exlax's Avatar
Thanks broski. I'll let you fellas know if I'm back up and running once I get the new one on. Never letting my wife drive my fucking car ever again.
Old Apr 20, 2015 | 09:01 PM
Skirmich's Avatar
But that Relay rarely goes bad it only turns on the Fuel Pump it does nothing to the F/I System.
Your issue sounds like the infamous Heat Soak at the Pressure Regulator, There is even a Thread on the Main about it.
Old Apr 20, 2015 | 09:07 PM
01acls's Avatar
Black if original. Gray if replaced already.
It's kinda way up in there. One 10M bolt.
Old Apr 20, 2015 | 09:08 PM
Skirmich's Avatar
^ Why did yours failed?
What where your symptoms?
Old Apr 20, 2015 | 09:12 PM
Skirmich's Avatar
What tips me off to believe its the Heat Soak problem is the 20 Minutes Threshold to Work again... A dead relay stays dead.
Old Apr 20, 2015 | 09:44 PM
01tl4tl's Avatar
perhaps the OP is talking about the bad solder issue behind the board where the relay plugs in? that's a common issue, even pics of the fix on here with arrows showing break and repair
Is that what you are thinking MrXLAX?
please describe all symptoms and attempted repairs so far- that will help us find your fix
question:
the electrical back section of the ignition, not the key part, has been inspected for burning inside itself?
that's another common failure- especially if many keys or weight is on the key ring.
The green key light on dash means the anti theft recognizes the key
If ignition shuts off and on, the symbol will appear again
got to be careful with common part names versus acuras odd descriptions, must be something lost in the translation - even though the TL was made in the USA! it wasn't designed here~
I see skirm is here- does this sound right to you- the solder issue?
Old Apr 20, 2015 | 09:45 PM
01tl4tl's Avatar
try wiggling the key in the ignition while engine running in PARK gear
if its that part it should act up
Old Apr 20, 2015 | 10:18 PM
Mr Exlax's Avatar
I'm too big to fit under the dashboard. I'm gonna have to wake up one of my kiddoes. I think I'm talking about the Fuel Pump thing. Car is cranking but not turning over. It cut off while driving like twice last week but started back up. Today it cut off, but it's been hours and it still won't turn over. I bought the new relay just can't get it on. If that doesn't work, I'll try something else. I have more money than I have time kinda thing. I might have to call out a mobile mechanic if this fuel pump relay doesn't fix it.
Old Apr 20, 2015 | 11:35 PM
01acls's Avatar
To test the relay you can just unplug the connecter and connect it to the new relay. You do not have to remove it.
Old Apr 20, 2015 | 11:39 PM
01acls's Avatar
No, its not heat soak. Heak soak doesn't shut off while driving.
Old Apr 21, 2015 | 12:42 PM
I don't think that's true... the main relay issues usually stem from bad solder joints. Relays rarely die themselves though. Just fix the solder issues by resoldering.
Old Apr 21, 2015 | 01:54 PM
Skirmich's Avatar
Never heard of this issue before
If the problem is the Solenoid leg joints then its probably that it will malfunction.
But a really dead solenoid stays dead since the stator is the one that fries.
Old Apr 21, 2015 | 06:01 PM
666wokker's Avatar
I'll bet its an immobilizer issue, almost sounds like a new key is in order
I have a memory of a couple years ago on AZine here, so done had a similar issue, got a new key cut and programmed at the dealer and never looked back
Old Apr 21, 2015 | 06:16 PM
Mr Exlax's Avatar
I still haven't gotten the new relay thingy in. The car started up no problem this morning and I drove 50 miles and it didn't cut off. I drove it again at lunch and one more time after I got off. I'm going to try and look under there again today though.
Side note: I got my new hids put in finally and they look sweet. I'm gonna get me some 8k blue bulbs next just to have when I wanna feel young.
Old Apr 21, 2015 | 10:08 PM
01tl4tl's Avatar
8000k is way too high in the color spectrum, = you cant see shite with them!
4300 was stock, 5000 is suggested upgrade, 6000 is ok but loses a LOT of white light on the road to see things
I ran Kaixen brand (High dollar/quality) 6000k for a year, then went to 5000 and the difference is dramatic, and reason why I am adamant about the 5ks as best option
want to feel young? get some LED strip lights and put under the car!!
Old Apr 21, 2015 | 10:10 PM
01tl4tl's Avatar
ck your ignition switch back part by wiggling the key while engine running
ck the board where relay plugs in for solder breaks on the back side
Its most likely one or both of those issues, not some crazy new thing no one has ever heard of
These cars have certain failures, and we know most of them!
Old May 6, 2015 | 06:51 PM
Mr Exlax's Avatar
I'm gonna give it a shot this weekend. Shit stopped on me twice today. Started right back up this morning, but this afternoon I've been stranded about an hour lol. Just gotta get it home.
Old May 6, 2015 | 07:52 PM
01acls's Avatar
I'm gonna give it a shot this weekend. Shit stopped on me twice today. Started right back up this morning, but this afternoon I've been stranded about an hour lol. Jtheust gotta get it home.
Lol. Pop the lower panel off as stated in this thread and tap on the relay with someting firm like the end of a screw driver or a tool from the spare tire kit in the trunk while starting the car.
Old May 6, 2015 | 08:28 PM
01acls's Avatar
Mr Exlax, "ARE YOU GOING TO HIT THAT?" LOL
Old May 9, 2015 | 03:45 PM
Mr Exlax's Avatar
Welp I changed the relay. Will report back in a few days. Thanks guys!
vpasla1
Sep 17, 2016 07:24 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
malvothegreat
2G CL Problems & Fixes
Sep 29, 2015 08:00 AM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
