need help !!!
I just bought the "Daytime running fog light".
Item Description & Spec:
On the back side of the drivers side fuse panel there are 4 or 5 spots that you can connect a spade connector to. 2 are switched, 2 are constant and one is on when lights get turned on. Connect a fused wire to one of them (i dont remember off hand which is which, you will have to test)
