need headlight
Old Nov 21, 2006 | 11:47 PM
greentypes's Avatar
need headlight
Any advice on replacing a headlight. I believe all I need is the bulb. Acura or Autozone?
Old Nov 22, 2006 | 12:46 AM
brado's Avatar
new wheels = old school
ebay has the philips HID bulb for our cars for under $30 which i recently purchased. it's the stock 4300k color temp too. just search "philips D2R" and it will come back with many results. i did a buy it now for like 24 dollars or something like that. good luck.
Old Nov 22, 2006 | 01:05 AM
superfob's Avatar
You might want to buy a set because if you just replace one the color of the two might be off. One would be older then the other so there would be a color difference.
Old Nov 23, 2006 | 11:14 PM
greentypes's Avatar
Is it dangerous replacing them? The manual mentions something about power remaining in the wire eventhough the key is not in the ignition. I have a friend also that is an Acura mechanic, and he also mentioned that if you don't know what you are doing it can be messy.
Old Nov 24, 2006 | 02:15 AM
superfob's Avatar
You can just disconnect the battery if your worried. BTW you will need a t25 tamperproof torx bit or a tiny screwdriver to open the cover to get to the bulb.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
