Navigation Code
Old Aug 29, 2013 | 11:16 PM
Big Cope's Avatar
Navigation Code
Fam,
I replaced the battery in my 03 TL-S and the navigation has needed a code ever since. I've searched the forum and found this link in which to obtain the code, https://radio-navicode.acura.com/.
However, I am unable to find my serial number for my navigation in order to obtain the code. The serial number is not in or on the side of the glove box. I also do not have the original owner's manual. I did look on the back of the navigation unit in the trunk and got the serial number off of it and tried to use it, but I got the message saying that the serial number and VIN didn't match.
What should I do next?? I need your help...
Old Sep 24, 2013 | 01:42 PM
M-Roy's Avatar
4th Gear
what you do is turn key switch to on hold 1 and 6 on stereo and hit the on button on stereo make sure stereo is off first then you will see numbers appear tthose are ur serial number
Old Oct 10, 2013 | 01:58 PM
acfd16n78's Avatar
press your map/guide menu and cancel buttons. this will bring you to a diagnostic screen. press the unit info soft key on the screen. there you will find you serial #
Old Oct 14, 2013 | 02:28 AM
ErickUa5's Avatar
Mr.Helpful Diagram
If non of the above works the serial number is on the bottom of the navi dvd player in the trunk you will need to unscrew 7 screws to see it.
dirleton
Aug 6, 2024 08:19 PM
Jamus22
Jun 11, 2023 10:08 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
