NAVI question
Old Nov 20, 2006 | 05:47 PM
charlieTL-S's Avatar
NAVI question
Hi guys, I just got navi in my '02 TL-S...the only thing I find annoying is that the thing shuts down after like 10 mins...is this normal and is there a way to go through a setup menu or something ang change the setting?
TIA
Old Nov 20, 2006 | 05:57 PM
Niko2000TL's Avatar
...::AOA::...
the "charge" wire that sends a signal to the unit telling it the car is running must not be connected or loose, or you may have a bad alternator (as i did in my case)
the system uses this feature to keep your battery from dying when the car is not running.
Old Nov 21, 2006 | 05:50 AM
you're right. it is not connected as per Bolamite's DIY instructions...I guess I should connect it? where did you tap in?
Old Nov 21, 2006 | 04:43 PM
Niko2000TL's Avatar
...::AOA::...
i'll have to double check my schematics....if i remember correctly, it is pin A-21 on the plug furthest left on the guage cluster. its the largest plug on the cluster, but i'll double check my notes when i get out to my car, unless someone else can verify.
Old Nov 22, 2006 | 04:39 PM
so which one did you use niko?
Old Nov 23, 2006 | 11:24 AM
Niko2000TL's Avatar
...::AOA::...
It is pin A-21 on the 30 pin connector on the guage cluster (the one furthest left).
It is a white/blue wire. Just splice into that and that should take care of it.
Good luck, lemme know if there is anything i can help you with.
niko
Ol'Dave
Sep 5, 2020 02:56 PM
06TLMatt
Oct 2, 2015 08:14 PM
datadr
Sep 12, 2015 09:12 PM
Vejey Gandier
Sep 12, 2015 08:59 PM
Gianni Formica
Sep 7, 2015 08:28 PM
