navi problem
navi problem
Ok, now that the rear view mirror issue is taken care of, the next problem is the navi system. about 90% of the time, i get a blue screen with an yellow box in the middle that says something about hard drive and contact a dealer, and most of the time the clock in the lower right hand corner of the screen isn't working. if i have to go the dealer, it sound expensive. what do i do?
Im guessing you have a '99.
That system was different than the rest of the TL's after witch are disk based.
In the trunk there is a really small hard drive that is closest related to one found in an early generation iPod.
What you can do is replace it with a compact flash card with a specific CFlash to that harddrive adapter.
Search around, this happend to someone else, i think its in the diy page, as its an obscure forum factor, not IDE, but really wieird.
Harddrives only last so long and this is typical that it will die with all the vibrations.
You can get a new hdd from the dealer, or try the Cflash card way if your feeling adventurous. Talk to the dealer first if they are willing to program it for you - or maybe you can get the old harddrive imaged if it works some of the time at a computer shop, and then copied onto the new drive.
Here is how you fix it
http://www.navhelp.com/
its a pcmcia hard drive
you can go compact flash to pcmcia, witch will never break ->thats what that website sells pre loaded and ready to go - might be the best route - phone the guy selling the part
You could get a old drive from a wrecker...
Original poster, i looked a bit more, its pretty much plug in the new drive and your good to go - its in the trunk, under the back shelf in a black box, theirs a slot under a pop of cover i think - user replaceable, the website is current and has instructions, i would call that guy and find out the deal with it as that error is from a broken HDD for sure.
I replaced the hard drive system that came with my 99 with the DVD unit off of Ebay for about $300. I just took it to the dealer and they gave me the security code. It plugs right up like the hard drive system did. I have not had a problem since - I did this about 5 years ago. I tried fixing my original hard drive unit many times, with new drives from that same website you all are using...never really helped. Even though the DVD system is an older system it is as good or better than our new Tahoe's navigation. Alpine is still making disk updates so you are not out of luck there.
Awesome... Now get the 2011 navi update for 99 before it does off sale jan 31st.
at least let the new owner know about the security codes- where they are written down in a secret place~
and that a new disc will make the nav useful
thug= if you are still on the OE disc, yes the nav is pretty worthless
but the new or a few years old disc would have your city on it and actually find places without the `Unverified Route` bs~
jl
wouldnt a fully working nav make it worth more as a car overall at sale time?
ck the list on alpine for when your area was updated last
http://www.navigation.com/is-bin/INT.../Default-Start
you can buy a used disc of that version number for cheap online if its a few years ago
jl
I pointed him in the direction of NaviHelp and he now has a solid state hard disk replacement in and the navis working 100%.
They ship updated - so i think hes the latest he can go.
SidhuSaaB
05-30-2020 12:40 AM
