NAVI conversion questions
Old Nov 14, 2006 | 11:05 AM
charlieTL-S's Avatar
hi guys,
I have a question. I just did a navi conversion in my '02 TL-S. the problem I have is that the car is a little off...It doesn't really know which way you're going, it thinks sitting in my driveway that it is at 38 koster court (an address that doesn't exist) my address is 2 koster court and the street only goes up to # 13. is there a way to calibrate this thing or is the antenna not getting a good signal? bad ground? I can't see how b/c everything was clean??? it is not jumpy, just off base a little...any help is appreciated!
thanks,
Charlie
Old Nov 14, 2006 | 04:47 PM
Niko2000TL's Avatar
...::AOA::...
Hit and hold MENU, MAP/GUIDE, and CANCEL all at the same time, theres a diagnostic menu there that might help, also in the main menu hit setup, then others and theres a location correction feature get move the pointer to where you are.
good luck, any other questions let me know, i just did the conversion not too long ago
niko
Old Nov 15, 2006 | 07:30 PM
bump
BoricuaTL
Apr 8, 2016 01:08 PM
Type S Zero
Feb 17, 2016 02:37 PM
HondoGermany
23
Jan 8, 2016 03:01 PM
datadr
Sep 12, 2015 09:12 PM
ivegotthenav
Sep 11, 2015 07:51 PM
