Mysterious Clunking
Old Aug 16, 2013 | 09:20 PM
KatabaticSaint's Avatar
Mysterious Clunking
So I know I've been absent a while and I know this will sound vague but recently when I let off the brakes at a stop or come onto the gas initially from a stop there is a clunk I can feel it in the pedal and its decently audible as well any ideas?
Old Aug 16, 2013 | 09:28 PM
fsttyms1's Avatar
Ball joint, motor mount, radius rod bushing
Old Aug 16, 2013 | 10:11 PM
I'm thinking ball joint just replaced motor mounts last year, how do you test for a damaged ball joint?
Old Aug 16, 2013 | 10:29 PM
Skirmich's Avatar
^^Put your car in stands now with the wheel in the air, Grab it by the top and bottom and try to giggle it to the inside of the engine bay and out.
If the wheel moves a little bit (Knuckle moves away from Control Arm) then your Top ball joint is shot.
To test bottom BJ, Grab a jack and put it below your wheel (With the car on stands) then jack the wheel up and pay close attention to the Lower BJ! If the whole knuckle moves before the A-Arm then your Lower ball joint is shot. If both moves at the same time then its ok.
Old Aug 17, 2013 | 07:02 PM
3.2TLc's Avatar
Did ya replace all of the motor and tranny mounts ?
Recheck them first, then look at the front suspension. (Ball joints/bushings)
Old Aug 18, 2013 | 09:52 AM
NSXNEXT's Avatar
What year is your car? How many miles?
My vote is radius rod bushings.
Old Aug 19, 2013 | 03:42 PM
MBP 03's Avatar
If the ball joints check out fine, definitely have a look at your radius rod bushings. I have a set waiting to go into my TL-S as I have a similar clunk, but it also happens when pulling into and out of certain driveways and going over speed bumps.
Old Apr 1, 2014 | 10:04 AM
kennedyhuynh's Avatar
are the radius rod busings in front and in the rear? my noise feels/sounds like it's coming from the rear of the vehicle.
Old Apr 1, 2014 | 10:25 PM
01tl4tl's Avatar
ck the upper control arm bushings for front thunk over speed bumps and driveways
my 01 has been doing that and a glance in the wheel well confirmed failure
not too bad a fix, especially for the trick suspension crowd,,,more room to work
Old Apr 3, 2014 | 12:51 PM
I don't get any noise when going over speed bumps or driveways. the OP posted my exact problem to a T.
Old Apr 3, 2014 | 11:00 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Have a look at both transmission mounts on the drivers side, if broken that could be the source.
Old Apr 4, 2014 | 08:38 PM
01tl4tl's Avatar
also look at the brake caliper brackets
I have seen those bolts tightened by a shop with an air gun- WAY past torque spec,,140 lbs when spec is ~60
stripped/Ripped the threads right out of the bracket!
Every time the brakes were operated the caliper- now loose and rotating on the remaining bolt = noise..and serious brake issue
marcelft
Jul 10, 2018 06:17 PM
Skirmich
Oct 1, 2015 12:59 PM
DNS91
Sep 29, 2015 10:11 AM
Brandle34
Sep 23, 2015 07:20 PM
1Lieutenant
4G TL Problems & Fixes
Sep 10, 2015 08:39 AM
