Mysterious Bulb
Originally Posted by Miami Magna
Does anyone know what bulb is in the ashtray and the shifter and how to get to them?
im not sure about the ash tray bulb, but to get to the shifter one, you need to frist remove the plastic ring around the shift plate, then remove the shift plate itself (you have to unscrew the shift knob in order to remove the shift plate) and then you will be able to remove the plastic piece that lights up... then you will see the bulb. good luck.
also, what is it you are trying to do? did you do the led conversion?
ripit
09-26-2015 06:19 PM
