My TL w/ Eclipse 5510
Hey everyone, I got my 03 TL a couple of months ago and just put in the Eclipse 5510 navigation with bluetooth. O yeah also got my windows tinted...Let me know what you guys think.
How did you get the stock subs to work with the AVN unit?
I've got a Eclipse AVN 30D and I'm trying to get the Bose Sub to work with the unit. I can't figure it out since the AVN 30D has no RCA input/outputs. Everything is wire harnessed. If anyone can help me out, I'd appreciate it. I've even gone to shops like Pacific Stereo to try to figure out this issue...
Correct
There is not a single RCA output on the module. The only things that you can plug into the rear of the module are 5 different slots for harnesses, 3 of which are occupied. I'm trying to figure out how to wire the stock Bose sub into a harness to get it to work or to see if I can add RCA's via harness to get the sub to work. I was wondering if anyone had done this before or knows of someone who can point me in the right direction.
The Eclipse AVN 30D is basically the 5435 minus the RCA outputs...
use a loc (LINE OUTPUT CONVERTER) a "pack" just go to your local stereo shop or best buy or cuircuit city, theyve got them,
you could even save the time and just tap into your rear speakers so you dont even have to run the rca's down the car. the factory bose sub amp is very close to them.
get one of those and your good to go, the only downside is youll have to adjust your bass to adjust the sub. but hey you got a sub working.
there about 20 - 25 dollars, but im sure you can find them cheaper.
shoot me a pm if you need help hooking it up.... hope that helps.
jahkesh
04-16-2003 07:01 PM
