Is my Ignition switch going bad?
2006 NBP TL MT6/ 02TL-S
Car is an 02 TLS. Three times now the car has failed to start when I hit the key. All the lights on the dash light up as usual, and the battery does not seem low. First time I checked the gear shift lever to make sure it was in the right position, I kept fiddling with the key/ignition switch-wiggling & pushing on it, and the car finally started and ran smooothly & normally.
Yesterday, after work it would not start again...all electical stuff seemed normal, no noise or anything out of the starter. Hooked up another vehicle and jumper cables-that didn't help. Finally I kept wiggling & fiddling with the key & ignition switch until it finally decided to work. When it decides to work, no sounds of the starter or silenoid dragging or hanging up-the car jumps to life as usual. Got home and put the multi-meter on the battery-well over 12 volts.
This morning, won't start again until I wiggled and fiddled around with the key again, then it started right up and ran like it always does.
Is this most likely an ignition switch issue? Seems like I've heard these are somewhat of a problem on these cars?
Sounds like one but i have never heard of it happening on any thing but the 99s.
Received 1,080 Likes
Try something simple...
Take your key off the keychain and start the car holding just the key. See if it starts. We've seen issues with too many keys, other "stuff" on a keychain interfering with the chip in the key. Give it a shot.
I started off real simple- I shot some WD-40 into the key hole. I only have the car key, one house key, and the remote on my keyring, but I'll try just the key, but really don't think that is it.
The internet parts guy at Acuraautomotiveparts.org says the ignition switch does indeed go bad on these as he regularly sells them, and from my description, he believes that is most likely my problem, not that he is a mechanic, but FWIMBW.
FYI-that is part #8 on the exploded parts diagram under "combination switch" heading. Also there is an Auto Zone switch for about the same price without the shipping.
wd works, but crc electrical contact cleaner is the right choice for this job IF cleaning were the solution
I have heard of later than 00s having the switch back wear out
and many 99 owners going to zone for the part (hoping different maker than acura used)
I like some stuff called SuperLube with teflon that is better lubrication than WD40 and is safe for electrical contacts, etc.
And I don't really know if spraying lub down the keyhole is even reaching the actual switch behind it. But...hasn't acted up since, so who knows.
wd is fine on electrical and I forgot the lube for lock clinders,,you are good Sir!
just drop dollars at my feet,,I dont need the bowing
Update....Not ignition switch
This no-start happened again on a warm day when I had the windows down. It became immediately apparent it was the starter solenoid as I could hear it clicking under the hood as I turned the key. Cleaned all the contact points on the battery, starter, and grounds-didn't help
Sooo....my stater solenoid went bad at 140,500 miles. Installed $120.00 rebuilt starter yesterday-only takes about 30 minutes and you don't even have to get under the car for anything.
The car now cranks much faster than before.
hmmm good to know Alan
Now we have a suspect in the funky ign switch sysmptoms
Did you ever get an electrical system test while this was going on?
It looks for starter draw (gets higher near failure) as part of the testing
Wont hurt anyone to get system checked for free at parts stores, now before a failure occurs
Acura604
20
08-05-2017 12:55 AM
xsilverhawkx
09-28-2015 06:51 PM
