My HID Fogs are...
Go Brewers!
My HID Fogs are...
My HID Fogs are... FINALLY ORDERED and on their way!
Thanks to HIDExtra.com and the 4th of July sale that is offered on this Black Market thread!
Got new 5K low beams as well because mine are turning pink...
Would you guys recommend LED fog light bulbs?
There are couple posts on them but nothing too recent (dead pics)
I don't wan't to put in too much $ but don't want to spend on something that looks
(you guys with the hid kits look
120%).
One of my fogs chipped (a cone like hole) story short I plugged it and put in a temporary 9$ "yellow" halogen bulb (I'll post some pictures) (looks off with the 6000k ish halogen bulb on the other fog). I like the LED bulb as if a bit of moisture gets in it wont be the end of the world - and I could coat them in epoxy or silicone to waterproof them.
What would you think about one of these?
http://cgi.ebay.ca/2x-White-68-SMD-9...item335ee3e645
.I don't wan't to put in too much $ but don't want to spend on something that looks
(you guys with the hid kits look One of my fogs chipped (a cone like hole) story short I plugged it and put in a temporary 9$ "yellow" halogen bulb (I'll post some pictures) (looks off with the 6000k ish halogen bulb on the other fog). I like the LED bulb as if a bit of moisture gets in it wont be the end of the world - and I could coat them in epoxy or silicone to waterproof them.
Go Brewers!
Got them in the mail today!
Either I get them in Thursday after work, or I wait until next week.
I have a bachelor party to go to from Friday afternoon and all weekend to Sunday in a cabin on the lake in Wisconsin Dells.
I'll be sure to post pics after I get them in too!
Go Brewers!
So the shipping was awesome and I absolutely had to put them in.
I've been missing a fog light for quite a while now and dealt with it, once I started to notice the pink in the headlights...
I decided it was time!
I have them installed and in, turn out there is something else wrong with my fog light though. All this time I thought it was burnt out, but I guess there is an underlying problem somewhere else. I'm not getting the HID to turn on.
I tested the ballast and bulb on the other side and it does work, I reversed the polarity and it didn't fix it. Now I have to trace down the problem.
It is on the passenger side and the washer-fluid pump is getting power (looks like it comes from the same line). I have to investigate...
Suggestions welcome...
Go Brewers!
There were a series of events that led to my problem.
The original fog light was in fact burnt out.
One of the wires was loose in the connection.
And I didn't have the connector in all the way.
-you can't flame me though because the way the connection is designed, I had to cut out a notch for it to slide in all the way. I had to reverse the polarity on it.
I took these pics in the garage and my dog, Murphy, had to get in on some of them... Shoulda turned off the garage door light though, oh well...
I LOVE 'em! Had to go for a drive and it looks great! I look hot!
Camera doesn't do justice! I got one good pic that really shows the yellow in the 3k fog.
The 5k low beams aren't too far off from the 4.3k stock ones I had. No more pink though!
As usual when working on a project, I have extra parts...
One is from the fog light, some thing broke and it seems like it's a little loose.
The cylindrical object is confusing, Murphy was playing with it when I saw it, so I am not sure if he dropped it by me or if it came off my car...
This has been on my DIY-To-Do List for a long time!
IT'S FINALLY DONE!
(For future DIY'ers, it was an easy DIY for my '03 and much more affordable that I thought it was going to be.)
IT'S FINALLY DONE!
That looks great!!!! :gheywave:
Actually, maybe, sign me up!
If you don't mind, I have a few questions myself...
Did you have to pull off the bumper to install it? (otherwise is it going to be messy?)
I am thinking of getting these puppies:
...as my fog bulbs mismatch and I use my fogs a lot.
Can LED's compare to these interns of looks and functionality (i know they wont be as bright but...) or will they just be a waste of $$...
I had the same issue..my passenger side fox wouldn't work so I tested the ballasts and fogs on the driver side and it worked. I tried to flip it and that still didn't work.
You just made sure it was snug inside? The stock fogs when I put it all back works, but when I put the HID kit only driver side works...
Im at a loss of ideas.. I bought my kit at the same place... went with 6k for 9k on my fogs and 6k for my headlights.
Jul 16, 2017 07:33 AM
