My Fading Door Trim Project for the Weekend
Hey guys I just wanted to post this up for anyone who may need help with this.
I'm going to fix the the fading door trim because they are starting to look like SHIT , and after bothering the local Cerritos Acura they told me that this type of mishap is not covered after 50k (when factory warranty is expired) I think thats a load of SHIT because why should it matter if its 49k or 51k its still Acuras cheap, faulty design/ shitty parts.
These parts cost around $50 - $60 - brand new, I thought I could give it a try and if I somehow mess up, I will just buy them. And they charge like 300 labor or something outrageous like that.
I have included some before pictures, and hopefully will be posting after pictures.
Here are the instructions in *.pdf format:
http://www.geocities.com/fastandthef...us/b04-033.pdf
These are the diagrams that it reffers to:
Hope this helps!
Hope this helps!
thats great!
but there was a guy on this forum did a carbon fiber custom trim on there.. i think imight just go with that. i dont want to buy and extra oem part and after driving another two years find out that its fading again
I got two of my trim pieces replaced Monday. (Why they didn't just go ahead and replace all four, dunno....will probably have to go back again in a year to get the other two replaced when they go bad).
But anyways, they didn't take my door apart. I was occasionally glancing through the window to look at the guy doing the trim, and they never had my door apart. You might want to check into that to save you some effort.
extended warranty coverage?...
I wonder if this is covered if you have the extended new car warranty for after 4y/50k? Anyone know? I'm going to call up Acura Care and see what can be done about this...
BTW, my car is still under the 24,000 Certified Pre-Owned new car warranty which extends past 50k, mine goes to 62k, and i'm just under it!
Upon calling them no one picked up the phone, so I had to leave a message for them to get back to me on the next business day. I'll see what happens...
Originally when I went to see a friend of mine, that works at the Acura body shop where I got my car he said that this was going to be a recall, so I called the dealership and asked about it in the service department. So he said it is covered up to 50k. At the time I forgot that the 62k warranty that I have is the same as a 50k warranty if you buy new, so I'll be calling them back to make sure they take care of my car... and do a better job of vacuuming out my car too!
Originally Posted by actright
Does any1 know what does goodwill consideration mean, it is stated in the Acura service bulletin in my first post in PDF format. Please advise
Had the same problem with my car. I ended up just buying new ones cause I didn't feel like going through the hassle. If it happens again though I would be interested in doing what you've done...as long as I like the way it looks. Only took me about 30 minutes to do driver's side front and rear. Very easy to do. Looking forward to some after pics.
That looks exactly like what happened with mine, but I got it in before the warranty expired. That is a taped piece, in fact all of the trim on the windows is tape. What they did with mine was to send it in to the body shop and they disassembled the doors to get the pieces all out, then stripped and PAINTED them. It looks great, used high gloss just like they looked before.
I was told by the service manager this is a common issue with our cars, does not happen with all of them, but when it does, its not something that just reaches a certain point and stops. He also stated that it he felt that it was stupid that they had used tape to begin with.
SO.... as a word of warning, If you see this (delamination) or like bubbling on the trim around the windows and you are still under warranty, get it in to get it fixed, and make sure they PAINT it rather than replace it with tape covered pieces. If you are out of warranty, take the pieces to a body shop, and get them painted.
Finally done, after debating it for a while.
Hey guys I finally did it, It came out like shit so please laugh on! I had some vacation time so I just went down and used whatever was in my garage to do the deed. Hope you like.
first encounter
bend it a little more
there she is, time to drill her
gotta yank this out
yank yank
stripped naked
its off
the only tools needed, plus my mits
sandpaper from my model kit
wetsanded that mug
all sanded and ready to paint
1st coat
2nd coat
finished:
there it is guys, still some crustation up on there, I started to run out of paint and I held the can close to the trims *I was getting desperate that I wouldn't have enough) Im going to redo them this weekend, at least the paint will give me some surface area to sand.
So yeah it aint that bad, go for it.
first encounter
gotta yank this out
yank yank
stripped naked
its off
wetsanded that mug
1st coat
2nd coat
finished:
Some tips for you:
It looks like you did a nice job sand prepping initially. You should do that again, but this time prime and sand before painting to get an even smoother surface for the paint to stick to.
Then paint like you did (though don't spray so close, as you already learned ), 2 or 3 coats of black gloss finish if you can find it. And be patient waiting between coats (I always screw that one up...).
Let it dry - preferably 24 hours in dry weather to play it safe - and then shoot some clear coat on it. It is key to let the black paint dry thoroughly before clear coating. Otherwise, the paint will start lifting, and it will look awful.
Good luck. I say 2nd time is the charm in this case!
P.S. Funny, I had all kinds of problems and issues with my '02 TL-S, but I never had this one.
How'd putting it back together work out? Was it tricky? Are the seals and everything as tight as it was before? I'd hate to take the trim off to fix and end up with some irritating rattle somewhere.
if I had a dollar for every paint job I f*cked up, I could buy these pieces new from the dealer!....great job!....like it was said before, sand them again, shoot some primer, sand the shit out of it till it's smooth as a baby's ass, then lightly paint 3 coats then shoot some clear......props on getting the things off the car!...and showing us...thanks for the DIY.....g
Originally Posted by TL_Fo_Life
How many coats of paint did you use? Did you use any clear coat? It looks like you need to redo it, but now that I've seen it done I'll do mine.
Originally Posted by caha14
You've got the disassembly/assembly process down, so it's great that you'll redo it.
Some tips for you:
Some tips for you:
Im cheating.
I got Tim Smith to get the parts under warranty and all I pay for is 1 hour labor.
Beats paying for 4 new ones.
I have enough projects at home that require sanding, dont want to do it on my car also.
But best of luck to you diy guys!
I tried and totally screwed up. TIP: Let the paint dry long enough before you spray the clear coats. I did'nt. The black paint "lifts" off of the plastic.
b-4
after
But I did paint my shift plate.
I'm gonna try again next week.
b-4
after
