Motor Mount Part #s!
Hi guys, i need to replace my tranny, found a deal ($1600) at a local JDM store for a fully rebuilt tranny with 20k warranty. And right now im thinking of doing the motor mounts at the same time. Surely someone has the part numbers written down somewhere, if you could post it up id be extra happy!
http://www.acuraoemparts.com/delray/jsp/home.jsp
I find my part numbers from this site. Just input your vehicle info. Search under engine mount catagory
do the front for sure,
and possibly passenger side if you actually find oil traces or broken rubber on front mount--
inspect from under the car looking up- small oil drops or trail from the front mount means failed
when the front has been broken a while the pass side takes more load and breaks
I just changed the front and side passenger mounts yesterday.The front was shot and I could hear the clunk when I would gas the car while in "Drive". The side passenger mount, I could not tell if it was going bad while still mounted to the car although I did do the pry bar test. Once I had it removed I could see the rubber beginning to tear from the mounted points of its frame.
^Yep 01tl4tl . Went to my mechanic, he said the same thing. He showed me that the passenger side is quite bad. He shook the engine a bit from pass side and even i know that it should not wobble they way it did.
To be honest with you, im not sure if they were ever changed. My car has 292Km so a few under 200k miles. How bad do the other 2 get? And is it absolutely necessary to change the rear and driver side. Money is an issue like for most people unfortunately.
My ride has 114,000 and change. I replaced front and pass side, they were bad. I looked at the two at the trans and they need replacing too. Didn't check the rear enine mount, too scared to see if it needs replacing too.
^Faaaak, lol i dont want to know either. I don't understand is it just our cars with these random ass problems or do all cars have this? I love my TL to death but damn im getting so frustrated!
Can somebody point out the #'s in the diagram for the mounts that need to be replaced. (front and pass side)
Also, please point out the rear and 2 at the tranny as Boriqua TL has refered to.
I am getting together wear and tear parts that I will be changing over the winter...thank you in advance
Illustration No. Part Number Description Required Qty. Year Model List Price Our
sockr1
10-01-2015 01:31 AM
