In the middle of clearing my headlights, need some help
Old May 4, 2002 | 12:13 PM
payyourtoll's Avatar
Question In the middle of clearing my headlights, need some help
Ok, got the headlights apart, and Im trying to scrape off all of the original silicone before I re-seal them. Whats the best way to do this ? Ive been using a razor and a flat-head on the dried stuff, and its not working so well. Should I re-heat the old silicone to remove it ?
Old May 4, 2002 | 01:03 PM
ElegantTL-S's Avatar
¤ Club Inspire ¤
Re: In the middle of clearing my headlights, need some help
re-heat the old silicone and try to remove with a flat head screwdriver. but the screw driver will be full of the silicone.
Old May 4, 2002 | 01:17 PM
Yeah, just heat up the old Honda Bond and use a flat head screwdriver to remove the old adhesive, then quickly take it off the screwdriver and throw it away.
Old May 4, 2002 | 03:42 PM
JPritch's Avatar
All Hail the Chief
Once you get 'em open, be careful not to touch the chrome reflector housing! You'll get fingerprints on 'em, you might crack the housing, and a number of other potential catastrophies! So be careful!
Use latex gloves if need be.
Old May 5, 2002 | 01:55 PM
Bitium's Avatar
Retired MOD
I don't removed the original silicone, because I couldn't find an equal or better replacement. I just make sure all the original silicone stays in place, so when I put the case back together it goes back perfect and you can't hardly tell it was ever open. So I would suggest re-heat the original silicone and if you want add clear adhesive silicone on the outside after the casing is close.
Old May 5, 2002 | 05:11 PM
Control's Avatar
make sure that there are no open cracks when you put it back together!!! you dun want those headlights to fog up
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
Mr.Tea
Oct 2, 2015 10:32 PM
jmaxima03
Sep 27, 2015 10:22 AM
