Max the 2000 out and the check engine light starts blinking...
Old Oct 8, 2005 | 04:01 PM
Bambo2888's Avatar
they go wooooot wooooot
Hey guys,
Well, I was seeing what the max was in my new 2000 tl-p (on a closed, certified track, of course.... ) and right at 120, maybe 118, the check engine light started blinking. So when I was slowing down on the offramp, i mean, post-race lap... it stopped and everything was fine. Anyone have any ideas?
Old Oct 8, 2005 | 04:56 PM
yunginTL's Avatar
trill recognize trill
Originally Posted by Bambo2888
Hey guys,
NO IDEA, how did you exactly max your car out?
Could it be the tranny?
Old Oct 8, 2005 | 07:18 PM
SSMTL01's Avatar
Mines done that before as well- never had any problems after
Old Oct 9, 2005 | 01:42 AM
crazym0nkey's Avatar
Doesn't the check engine light come on if you stay in vtec for over 15 seconds in the same gear?
Old Oct 9, 2005 | 02:18 AM
REDLINEN's Avatar
Missing my Acura's
I dont think so. When I maxed mine out I know I had too be in v-tec for more than 15 seconds in 4th gear, No lights.
Old Oct 9, 2005 | 03:01 AM
SaNJoSeTLRydEr's Avatar
just try not to max ur car out anymore..hahaha...
Old Oct 9, 2005 | 03:14 AM
Fossil_TL's Avatar
mine went 130mph before. no problem with check engine light at all
Old Oct 9, 2005 | 03:53 AM
whatwasthat's Avatar
you sure it was the CEL?, i don't think they blink, TCS light blinks...
maybe you mistaken it for the TCS light, esp if you're going 120...
Old Oct 9, 2005 | 11:25 AM
NYbsbl04's Avatar
I went 140 and nothing happened..car was fine at that speed
Old Oct 9, 2005 | 11:29 AM
Pure Adrenaline's Avatar
Dragging knees in
TCS isn't functional at that speed.
I'm thinking it was probably a misfire code.
Old Oct 9, 2005 | 02:48 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
CEL's do blink, and it means that the engine cannot prevent damage to itself. If the CEL is just on constantly, the computer can do some compensation.
At least this was my understanding.
Old Oct 9, 2005 | 03:13 PM
@cUr@-TL's Avatar
'99 Acura 3.2TL
pure adrenaline is right. If you looked up the code you would probably find something like cylinder #1 misfire.
That's caused by a clogged EGR port. get it cleaned, or clean it yourself.
The same thing happened with my car, i cleaned the EGR port/intake manifold, and the light never came back. and i know other people who had the same problem and cleaning the EGR port took care of it 100% of the time
Old Oct 9, 2005 | 05:18 PM
mrsteve's Avatar
Where the hell did you hear that
Old Oct 9, 2005 | 05:19 PM
mrsteve's Avatar
A flashing CEL is a random misfire.
Old Oct 9, 2005 | 05:30 PM
I swear I read a thread a long ass time ago where this guy let his wife drive the car, and she left it in sport shift and never shifted while driving on the highway. Thought I read something like his check engine light was blinking cause she was constantly in vtec.... or was it redline ... maybe it was redline, that makes more sense if the check engine light would come on?
But I'm probably wrong so don't listen to me
Old Oct 9, 2005 | 05:38 PM
mrsteve's Avatar
I've driven both my cars pretty hard and I'm sure I've kept them in VTEC in the same gear for more than 15 seconds without a problem.
Old Oct 11, 2005 | 08:55 PM
Bambo2888's Avatar
so how do i clean the egr port? if thats the problem at least...
Old Oct 11, 2005 | 09:15 PM
fsttyms1's Avatar
very easy. mine cloged also around 70k and i just did them again not that long ago
Post #4
http://www.acurainspired.com/forums...?showtopic=4003
start off by getting 3 or so cans of SPRAY carb cleaner and acouple small scrub brushes.
if your engine is any thing like the 2nd gen
baisicly you take the plastic engine cover off 4 10-mm bolts. then disconect the battery. they disconect the rubber hose that goes from the air box to the throttle body. continue to unplg any thing that goes to the intake (any plugins hoses) then there are 10 10mm bolts on the top plate (the part that sticks up thru the plastic engine cover) oull that straight up being carefull to not damage teh gasket. then there are like 8 bolts (12mm i think, i cant remember off the top of my head) then you are able to pull the upper part of the intake manifold off (double check before you pull straight up that every thing is disconected) then get your self a nice place to work and start cleaning. (stick a bag over the TB before you hose every thing down like in my pic to be safe)
it sounds like alot but its really easy should take about a hr to do
Old Oct 11, 2005 | 09:26 PM
Bambo2888's Avatar
Post #4
link doesnt work...
Old Oct 12, 2005 | 12:03 AM
FiftyFive's Avatar
Moderator Alumnus
yea, you would not want to see your TCS flash at that speed
Old Oct 12, 2005 | 07:33 AM
JimmyTLS's Avatar
VTec doesn't actually engage unless your at WOT. It can be above 5K but unless your foot is to the floor, it won't engage.
Old Oct 12, 2005 | 08:59 AM
fsttyms1's Avatar
link doesnt work...
here try this http://www.acurainspired.com/forums/...showtopic=4003
Old Oct 12, 2005 | 11:06 AM
03CoupeV6's Avatar
Not true. Put your car in second and just gradually let it increase in speed and RPMs. As it gets to the VTEC changeover you will hear it.
Old Oct 12, 2005 | 01:43 PM
Flashing Check engine light can be alot of things, plug in a OBDII reading and see did your ECU store any code. Remember not all code will cause the check engine light to stay on.
Old Oct 27, 2005 | 12:20 AM
@cUr@-TL's Avatar
'99 Acura 3.2TL
VTEC will always engage over the set RPM point. No matter if you're at WOT or not. It has nothing to do with throttle position.
Old Oct 27, 2005 | 01:01 AM
Dragging knees in
VTEC = 100% RPM-dependent
i-VTEC = throttle-dependent
Old Oct 27, 2005 | 08:04 PM
Bambo2888's Avatar
i guess ill try the egr thing and get back...
Old Oct 28, 2005 | 07:40 AM
fla-tls's Avatar
On the way!
I heard VTEC won't engage if you're running 87 octane. It's because of the octane sensor in the tank!
Old Oct 28, 2005 | 07:41 AM
fsttyms1's Avatar
Old Oct 28, 2005 | 07:51 AM
Bambo2888's Avatar
umm.... i have nothing to say
Old Dec 8, 2005 | 12:50 PM
SSMTL01's Avatar
will cleaning out the egr/intake mani give noticeable power gains/gas mileage improvements? My car has 124k and I'm pretty sure this hasn't ever been done.
Old Dec 8, 2005 | 01:05 PM
Dragging knees in
Old Dec 8, 2005 | 01:30 PM
99TLHeather's Avatar
LMAO
Old Dec 8, 2005 | 02:29 PM
fsttyms1's Avatar
if the car is suffering from clogged or clogging ports you may see a slight improvement
Old Dec 8, 2005 | 05:14 PM
tommiesay's Avatar
Acura TL 2000
i went 140 MPH with my car.....nothing happen to my car....
Old Dec 8, 2005 | 09:13 PM
fsttyms1's Avatar
i did 154 in mine and nothing happened to mine. What happened to him was a fluk and doesnt happen if you do go that fast to every one
Old Dec 11, 2005 | 07:48 PM
seter's Avatar
doesn't the computer monitor engine temp and oil pressure, and if it doesn't meet requirements it will not open the VTEC solenoid?
Old Dec 11, 2005 | 09:06 PM
Dragging knees in
Well, yeah, if you want to get technical.
We were just talking about how each type of VTEC is engaged. Of course, that was assuming the engine was warmed up to operating temperature for VTEC to engage with proper oil pressure. Otherwise the PCM won't engage the VTEC oil solenoid.
Damn electronannies.
Old Dec 11, 2005 | 10:49 PM
03CoupeV6's Avatar
I've never heard of VTEC being temperature sensitive. I was under the impression the only way VTEC would not operate is low oil level or low oil pressure.
Old Dec 11, 2005 | 11:40 PM
Ryons02TLTypeS's Avatar
Not true.... It will engage over 5200.... til 7200 RPM......
