Manual shift mode?
Old Oct 11, 2007 | 09:59 PM
spoonspec's Avatar
808 Honolulu
Manual shift mode?
Who uses manual shift mode as a daily basis when driving their TL?...I dont....all my cars Ive owned were manual standard trannies and Im tried of shifting already...although the TL dont have a clutch...Im still to lazy to go on manual shift mode.....hmmmm do you think the cause of our tranny issues is caused by daily use of shift mode?....
Old Oct 11, 2007 | 10:21 PM
orgnlprankster7's Avatar
08 Civic SI
i use it on a daily basis for more "spirited" driving. using it wont damage the tranny unless you downshift to brake (thats a big ). our trannys just wear prematurely and fail, chances are even if you drove like a grandma it would still be toast sooner or later.
Old Oct 11, 2007 | 10:28 PM
ChrisQ1980's Avatar
hates the winter
I only use it on occasion (spirited driving) It only makes a slight difference IMO.
Old Oct 11, 2007 | 10:42 PM
Never Summer's Avatar
I've gotten so used to using it daily that today when I was driving in D5 I accidentally put the car into neutral out of instinct I guess.
Old Oct 11, 2007 | 11:05 PM
Mastermind's Avatar
Don't try this at home
I use my tranny to brake, (from 70 into 2nd )i got around 82k miles on it, and got green lights for tranny change from the dealer, for free of course, gonna pick on it some more during the winter and and bring it in April to get it done, yepeee.
Old Oct 12, 2007 | 08:45 AM
fsttyms1's Avatar
SS mode isnt the cause of our failures.
Old Oct 12, 2007 | 01:09 PM
dreem1er's Avatar
deal with it
i know someone with an 03 tpye S, and he drives like an old woman, he has also gone through three trnnaies....SS mode isn't the cause, and SS mode is prolly safer than driving with it just in drive, in SS mode the pressure is increased in the tranny to get a better response out of it with less slipping....
Old Oct 12, 2007 | 01:57 PM
randomthought's Avatar
rebmeM deretsigeR
I use SS daily. Mainly to slow down when coming up to traffic or when i want to shift earlier than the computer wants to. Easier on the tranny I think.
Old Oct 12, 2007 | 02:25 PM
01tl4tl's Avatar
Better read up on how these things work
BRAKES slow the car
Transmission gear select is to be in the right rpm/torque to accellerate off the corner, or late brake downshift turn in gas it and go corner
NOT for use to slow down in traffic
Extra pressure to be ready??---where are you geting this info
All matters of transmission should be deferred to fsttyms1- our Guru of TL gen2
Old Oct 12, 2007 | 02:50 PM
Bearcat94's Avatar
AZ Community Team
Every time I drive it. Click over to SS out of habit.
1st tranny, still going strong ~65,000 miles.
Old Oct 12, 2007 | 04:22 PM
acutee's Avatar
Don't forget old woman even drives car when it is on fire, when tires are blown, when oil is empty, when brake pads are on metal, when cops are chasing them...
I hope he didn't totally drive like woman...
Old Oct 12, 2007 | 04:29 PM
missingH22's Avatar
I keep it in regular mode, since whenever I use ss I usually forget that I am using it...wish I had time/money to switch to a 6sp...miss manual
Old Oct 12, 2007 | 05:29 PM
rebmeM deretsigeR
BRAKES slow the car
I meant to slow down maybe 5mph, not a LOT. I didn't mean to slow down from 65 to 30 with no brakes, thats just plan stupid.
Old Oct 12, 2007 | 07:16 PM
01tl4tl's Avatar
If you are in stop and go traffic- put it D4 to make it work best- keeping it out of overdrive in that 35-45 range
USE the brakes- a tap is 5 mph
there are clutches inside the transmission- guess what goes out in our car???
Old Oct 13, 2007 | 06:50 PM
dreem1er's Avatar
deal with it
picture driving miss daisy....
Old Oct 13, 2007 | 08:19 PM
illjuan3's Avatar
Our trannies have more stress on them trying to make a smooth normal as compared to a hard SS mode shift. Check into shifter kits for cars makes trannys shift hard but extends the life of a tranny!
http://www.hondacarforum.com/honda-t...ft-kit-do.html
Old Oct 13, 2007 | 09:20 PM
6MTUA5's Avatar
No He Can't
^^ Then we'd go through motor mounts even faster than we already do
Old Oct 13, 2007 | 10:24 PM
08 Civic SI
^^maybe not if combined with the innovative polly mounts.
BUT it has to be expensive, and our trannies are flawed from the getgo, i doubt it would help because if it did someone here would have done it already.
Old Oct 14, 2007 | 01:19 AM
illjuan3's Avatar
no one here will do it because the TL is a luxury vehicle...NO one should do it to a tl i was just stating a point that SS mode isnt bad for our cars but more benificial especially when hauling a**. Dont you agree?
Old Oct 14, 2007 | 01:31 AM
2K3_TLs's Avatar
OMGWTFVTEC
If SS mode was so bad for our trannies, why would we be given the option?
like fsttymes said, its not the cause of our tranny failure.
although i dont know bout them shifter kits.... like orgnlprankster7 said, if it was beneficial, someone on AZ would have done it already.
Old Oct 14, 2007 | 01:55 AM
innocentwinky's Avatar
malissatem.com
i dont even know how to use it... >_< normal driving for me.
Old Oct 14, 2007 | 02:08 AM
2K3_TLs's Avatar
OMGWTFVTEC
whaaaat???
dude even my girlfriend knows how. well she does
its not that hard... give it a shot sometime... its fun, i guarantee it
Old Oct 14, 2007 | 09:29 AM
spoonspec's Avatar
808 Honolulu
one quick question anybody? is it safe to shift into manual mode at high speeds?...i mean if your on auto mode and shift into manual mode while rolling at speeds of 50 or over...
Old Oct 14, 2007 | 11:37 AM
01tl4tl's Avatar
In the owner book is the upshift-downshift speed limits in SS mode
you can slip it over at 100, brake to 96 or less and go into 3rd gear!
It wont go into a lower gear that would cause over-rev of engine
If you try clicking down and the number light flashes 3 times- that means you were too fast and its staying in the next higher gear, brake a little more and try again.
Now it will go into 2nd-- play with it- its fun and you are not hurting anything
Old Oct 14, 2007 | 11:41 AM
01tl4tl's Avatar
There is no mechanical interconnect of the SS to the trans, the D5 isnt either
You trigger an electronic signal to the computer which looks at several issues and then shifts the gears
Running it manually from 1- D5 up the regular side gets same result- it shifts by science not brute strength
Old Oct 14, 2007 | 10:01 PM
fsttyms1's Avatar
i would have tried one if one had been available or known of back then.
Old Oct 15, 2007 | 01:57 AM
malissatem.com
whaaaat???
Hey hey didn't have to pull out the girlfriend card. i am a girl too. i just have very little experience with this stuff. my dad didnt want to me to learn stick shift and it would be super hard to keep going back with the clutch & all that with hells. yaddamean.. but if anyone has any pointers for the noob.. i am willing to take some suggestions.
I'll give it a try but i am seriously scared of screwing something up.
Old Oct 15, 2007 | 02:14 AM
illjuan3's Avatar
Ok i will say it again a shifter kit will have your car shifting really really hard there will be no smooth shifts that why no one has done it...nor should they do it on a TL. The TL is a fast car for whats its worth but its still a TL=Total Luxury....period dot
Old Oct 15, 2007 | 03:03 AM
6MTUA5's Avatar
No He Can't
First bring the shifter to the left in D5 mode to the + - . Just tap the shifter up, a little bit before you want to shift. There is a slight delay, but not much. You don't have to let go of the gas at all, just keep your foot steady on the gas and push it up to the + . Just practice, it's very easy to get used to. Then when you don't feel like shifting, you can always just put it back into D5. You're not going to hurt anything unless you are down shifting to brake.
Old Oct 15, 2007 | 08:22 PM
2K3_TLs's Avatar
OMGWTFVTEC
i didnt mean to... hell i had very little experience with that, yet something kept taunting me as id drive...
so i threw it in SS and pretended to know what I was doing... the best part of it is what 01tl4tl said
say it isnt so! i do that alot...
i thought it was the 3rd gear clutch packs, or something along those lines?
Old Oct 15, 2007 | 08:35 PM
Razzi's Avatar
T-Swzy
*brings out the dead horse and a stick*
Old Oct 15, 2007 | 09:21 PM
2K3_TLs's Avatar
OMGWTFVTEC
now i dont want to know how or when you got that dead horse...
Old Oct 15, 2007 | 09:40 PM
malissatem.com
he could of gotten the dead horse if he ran it over on some country road. LOL.. sorry i couldnt help it.
Old Oct 15, 2007 | 09:41 PM
malissatem.com
oh yes thanks guys i am going to try it around the block hopefully it doesnt go crazy on me..
fsttyms1's Avatar
Old Oct 15, 2007 | 09:54 PM
6MTUA5's Avatar
No He Can't
it won't.. it's really pretty easy and you'll get the hang of it if you practice.
Old Oct 16, 2007 | 12:00 AM
Gfaze's Avatar
S E L L
Originally Posted by fsttyms1
That one has to be added to the AZ smilies collection!!
Old Oct 16, 2007 | 12:10 AM
seanmcd's Avatar
On The Road
I've done that a few times recently. lol. It ticks me off when it happens.
Old Oct 16, 2007 | 12:21 AM
2K3_TLs's Avatar
OMGWTFVTEC
i did that once, revved it all the way to about 6.5k before i realized wtf i just did.
then i threw it back into SS mode.
Old Oct 16, 2007 | 12:22 AM
Bearcat94's Avatar
AZ Community Team
Yeah. Totally safe, no biggy. When you do this the car will be in the same gear it was when you were running Full Auto. Then you can up/down shift from there.
You can go back and forth between Full Auto and SportShift any time.
