Manual or Automatic tranny??
im trying to figure out how this manual-matic thing works... i know that when i shift it over to the left its manual but is this the best way to drive or should it be the automatic?
my bad man im just trying to see if driving it in manual is better for the car or auto is better? plus if im driving n auto then i switch to manual doesnt it give me a lil extra kik like n 4th and 5th?
In "D5" the computer tells the tranny when to shift based on several variables. In SS you TELL the tranny when to shift based on (one can only hope) some basic understandings of the mechanics of your car.
The tranny shift the exact same way just the sorce of the command to "shift" changes.
If you pay very close attention to when it shifts in D5 under all conditions and mimic that patern exactly in SS the tranny knows no differance.
The TL 5AT has 3 options:
Full Auto: Leaving it at D5, D4, D3 depending on what highest gear you want
SportShift: slap it to the left of D5 then up/ downshift like you're in WRC
Manual: Shift it down to 1 (very bottom of gate to the left) which should hold 1st gear, then 2nd then D3 up to D5 for the higher gears.
It's still an Auto tranny so in S/S mode and D3 to D5, you will coast when you let go of the gas unless you're in 2. Play around with it, also try to launch with the VSA turned off and see if you like it.
Pham Alvan
03-16-2016 09:17 AM
lanechanger
10-13-2015 10:56 AM
09-25-2015 06:14 PM
