Major Service Due!
Old 10-19-2001 | 12:02 PM
HOT's Avatar
HOT
Major Service Due!
My car is now 74000miles on it!!!
What are my options??
Should i go to the dealer or is there any other shops i can go for the 75000 miles service ????!
What's included in the service anyway...it it really necessary???
thanks
Old 10-19-2001 | 12:11 PM
thephantom's Avatar
I, personally, would go to the dealer. The service should run you around $120.
Old 10-19-2001 | 12:57 PM
juniorbean's Avatar
Exclamation
You sure about that? The 60k mile service is around $400. The way I'm reading his post I'm assuming that he never had that one done yet, and that's a major one. If you go in for the 75k and haven't had the 60k done yet, they will do both which would probably run around $500. If you haven't had the 60k done, I would do it b/c the 30k and the 60k are your major ones......
Old 10-19-2001 | 01:24 PM
songoku's Avatar
BlingBling INSPIRE 32V
I really want to know what kind job will be performed. If it's just fluid level check-up and something like that, it's not really worth it. They charging us hundreds of $$ doing what??
Old 10-19-2001 | 01:30 PM
thephantom's Avatar
My apologies, I read the mileage wrong. I thought it was the 7500 check up.
Old 10-19-2001 | 01:50 PM
99WDP's Avatar
I just had the 30,000 mile service done and it cost me $465.
Power flush engine coolant, flush radiator, replace coolant.
Flush engine oil, replace oil and filter.
Flush brake lines, replace brake fluid.
Change transmission fluid.
Balance and rotate wheels.
Flush intake system, clean injectors.
Carbon flush.
Fixed squeaking sunroof (warranty).
Expensive, but I've never had any problems with the car.
Pham Alvan
03-16-2016 09:17 AM
c1souk
09-28-2015 11:20 AM
95oRANGEcRUSH
09-25-2015 12:50 PM
Hines57
09-24-2015 01:58 PM
Quick Reply: Major Service Due!
