MAJOR aftermarket PROBLEM
hey guys, i got some brembo OEM Replacement brakes on my 99TLabout a month or 2 ago and there is something wrong on the wear of the rotors. please help me
That's with all the TL OEM rotors. Eventually you'll start to see rust deposits like mine (you'll notice it too if you look at the stock rotors):
So I painted that area with high heat paint (just make sure that the paint can withstand the heat.
You can check out more pics in my album
did you torque the lugs properly after the install? uneven torque on lugs can cause warp rotors. Mine was warped then it was re-surfaced. Since then I always get my lugs torqued properly and it has never happened again
After finding out those shops use 250-450 ft/lbs on their air impact wrenches, made me think twice about getting my own wrench and torquing it myself.
I don't think ebc pads are the problem.
I think tateaki may be correct. Ur lug nuts might be over/under torque, check if the lug nuts are loose. I remember when i took my car in to a local shop, they put the lug nuts back on but didn't tighten them. I heard noises when i was driving. Went out check my lug nuts, i could turn them with my fingers!
Alexx,
How did you paint them? Did you just spray the general area and went out and brake so it burned off the left over area?
Alexx,
Originally posted by fsttyms1
Originally posted by 04AcuraTL6speed
Alexx,
Alexx,
pistacio
Sep 26, 2015 09:45 AM
trinikidcl
Sep 4, 2015 12:56 AM
