Maintenance Req'd Light - Won't Clear!
We just bought a 2000 TL. Nice car, runs fine but the Maintenance Req'd light won't clear. I tried the procedure in the manual but no luck. Any other suggestions? Thanks!
I see this time to time on the 98-02 accords, and the culprit is the cluster itself. The TL has the same guts as the accord cluster for the most part. most live with it due to the price of the cluster.
just to verify method
place key in ignition
put left hand THRU top of steering wheel
with right hand turn key to ON, not start, just ON
press and hold in BOTH trip/reset buttons with LEFT hand
mait light will flash 10 times and go out
release buttons
turn key off
done!
give that a shot
its job is to count 6500-7500 miles since last reset- then starts blinking to remind you of oil change due
measures nothing but miles since reset
release buttons
turn key off
done!
give that a shot
3.2TLc (06-12-2013)
which light is it for sure?
Is that correct? Since it is a new car to you thought it would be worth asking so we can help troubleshoot.
doH! got my methods backwards
if you follow my above stated way= it gets into outside temp reading adjustment mode
goes up or down 5 degrees
should take about 10 sec for mait light to finish flashing and go off
once its off you are done
mada51589
05-03-2022 08:54 PM
rockyboy
01-25-2016 06:00 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
