Maintenance Req'd Light is constantly on.
Old Sep 14, 2001 | 09:13 AM
I think I posted it long time ago, about my Maintenance Light blinking on and off. Right now it is constantly on. I just reached 7,500 miles mark. Can that be a reason? Does Acura turn this light on to remind the drivers to go for a "rip off" check up that they do?
Old Sep 14, 2001 | 09:27 AM
thephantom's Avatar
Be ready to dish out $150 or so for the check up. This includes tire rotation and balance, oil change and other "check ups". However, you can reset the light yourself... check you manual.
Old Sep 14, 2001 | 10:39 AM
1000bpm's Avatar
Your light is on because of the 7,500 mile service.
Between 7,300 and 7,500 the light will flash on and off for about 10 seconds when you turn the ignition. After you cross 7,500 the light will remain on until you get it serviced.
Nothing to be alarmed about, I guess this is Acura's way of ensuring that you take your car in for servicing. I paid $110 for my 7,500 servicing yesterday, it included tire roatation, oil filer change, lubing the suspension and a bunch of "inspections". Overpriced? Definitely, but the way I look at it is getting your car serviced at an Acura dealer counts for a lot in out-of-warranty situations where the manufacturer is not legally obligated to help you but does so out of goodwill.
Old Sep 14, 2001 | 11:04 AM
fredjones's Avatar
How to turn off the maintenance required light
The instructions to turn this light off are straight forward and are found in the Owner's Manual. I believe you turn the ignition switch to the on position while holding down the the two buttons that control the trip meter to the right of the dash. Hold them for ten seconds and the light goes off.
Old Sep 14, 2001 | 12:58 PM
oracion's Avatar
Question
Does it come on only at the 7500's intervals?
Old Sep 14, 2001 | 05:39 PM
edgalang's Avatar
Purchased: April 28, 2001
yes....unless there really is something wrong with the engine. But if everything is running ok...then it wont turn on for anything less then 7500
Old Sep 15, 2001 | 12:33 PM
pianoman41's Avatar
Actually the maintenance required light only comes on to remind of service intervals. Starts blinking at 6,000 and stays on steady at 7,500. If there's something wrong with an engine-related component the "check engine" light will come on instead.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
BigJilm
Sep 21, 2015 08:32 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
