Maintenance Light Indicator
Old 06-20-2002 | 10:14 AM
Pls help. Does anyone know how to manually turn off the Maintenance Light Indicator on 02 TL... I change my own oil, but can't get the thing to turn off.
Old 06-20-2002 | 10:21 AM
check your owner's manuel. I had the same problem too, i think you during your key to the second turn, and hold reset for 10 seconds...or something like that, but your manuel should tell you.
Old 06-20-2002 | 10:36 AM
vperkins2's Avatar
Thumbs up
Did a quick search and found this reply in another thread. Sounded like good advice to me!:
Originally posted by derrick
slixx-tl ,
Wanna shut the light off? In the '02 owner's manual, hold the reset / select buttons (where you can toggle your mileage / trip computer) simultaneously for 10 seconds (about) when you start your car and it should turn off.
** only shut the light off if you've already gone to get your car serviced... ** It goes on for a reason...
- derrick
'02 EBP TL Type-S
Later,
V.
Old 06-20-2002 | 11:05 AM
songoku's Avatar
BlingBling INSPIRE 32V
Thumbs up
I'll make it little bit easier for ya.
Originally posted by songoku
Maintenance Require lights.
1. Press & hold both SELECT & RESET buttons.
2. Put the key in ignition (3rd position, right before start the engine)
3. Keep hold the buttons and wait till the light goes off. (Usually before 10 sec.)
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
ahsm
09-09-2015 08:35 AM
Phambam12
09-06-2015 06:57 PM
Quick Reply: Maintenance Light Indicator
