Maintenance
Old Sep 13, 2005 | 06:53 PM
ahmadjalil's Avatar
Maintenance
Ok it happened tday.
I have a 2000 TL with 64000 miles. Since today The maintenance light has started to blink when i turn on the car.
Any ideas on what parts need to be serviced, and should i go to acura or a regular mechanic.
Also when i start my car in the morning i feel very small vinbrations when the engine is idling, but after about 1 min the vibrations go away. Could it be the spark plugs? And did anyone else experience this before?
Any help is appreciated guys
Old Sep 13, 2005 | 07:35 PM
fsttyms1's Avatar
if you have a manual now would be a good time to read it.
The maint required light is just a dummy light. its a perdetermined mileage for it to go off. its supposed to be reset at every oil change.
as for the vibration, it could be a few thing, possibly the spark plugs or a coil, or something emissions related.
Old Sep 13, 2005 | 10:06 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
My TL runs pretty rough for the first few seconds when the engine is cold. It was my understanding this is an emissions-related normal characteristic.
Old Sep 14, 2005 | 08:09 AM
Bareback's Avatar
TL = Tranny Lubrication
60,000 mi/96,000 km/4 yrs Scheduled Maintenance
Recommended service for your 2000 Acura TL:
Replace engine oil.
Rotate tires (follow pattern on page 231 of your owner's manual).
Replace engine oil filter.
Inspect front and rear brakes.
Check parking brake adjustment.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
Inspect cooling system hoses and connection.
#Inspect exhaust system.
#Inspect fuel lines and connections.
#: See information on maintenance and emissions warranty, last column, page 191 of your owner's manual.
Replace air cleaner element.
Inspect and adjust drive belts.
Replace air conditioning Filter*2.
*2: See Air Conditioning Filter on page 226 of your owner's manual for replacement information under special driving conditions.
Old Sep 14, 2005 | 08:45 AM
fsttyms1's Avatar
yea ive been in a few (including mine) that when cold were tough for a few seconds
acuratl26
Apr 23, 2020 07:30 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LeVeL
Oct 18, 2015 04:19 PM
polish_pat
Sep 30, 2015 12:22 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
