Loose Front Door Handle
Old May 17, 2009 | 10:32 AM
dannheisser's Avatar
9th Gear
My passenger front door handle spring is loose. The outside handle "flaps" when locked but it will open the door when it is unlocked. I pulled the door panel but can't really tell exactly how the spring is to be set. Does anyone have a detail on this assembly?
Old May 17, 2009 | 09:46 PM
9th Gear
Old May 18, 2009 | 11:13 PM
MrFluffy's Avatar
To many cars in my garage
If you take apart the door it may be the rod that goes to the actual latch to the handel may have popped out simple fix once the panel is off.
It looks like a thin metal rod pops into a plastic slot
Old May 19, 2009 | 09:54 AM
9th Gear
thanks, but the loose spring is up at the actual handle, the rod is not loose
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
tman570
Jun 11, 2019 07:56 AM
marcelft
Jul 10, 2018 06:17 PM
08 NBP TL
Sep 8, 2015 08:49 PM
