Looking for brightest H.I.D..
Hey guys~ I got 2000 tl and my one of headlight bulbs are gone.. and this time Im trying to get a brightest brightest one... anybody got a information that will fit in my car??
Brightest or most light output to the road? There's a difference. If you want it to LOOK brighter by other people, get 6000k, or i think they make 8000k too, but dont expect to see much of the road with the 8000k's. You might want to go with the 6000k's. They look really bright and still have adequate light output to the road.
Rosh
Rosh
Blown is Best
This is how I understand it: The 6000K - 8000K number represents the color of the light (across the light spectrum). The illumination is measured in lumens. Some bulbs in order to get the higher "K" number filter out the light frequencies on the lower part of the light spectrum. By doing so, light output or lumens is reduced. It's sometimes a balance between having white light and good illumination (lumens). You actually want both numbers to be high - not just the "K" number.
actually 4100K, 6000K, 8000K all represent the temperature inside the bulb. (hence it gets really hot). 4100K is the optimal temp for which you get most luminescence. as you go higher, ure going to lose lighting but ull get closer to purplish color. go with the 6000K in my opinion. 80% lighting of 4100K is still a lot and it might actually look like you can see more because the ground is whiter with the 6000K bulbs.
Just out of curiosity can the ballasts handle the 8000Ks? I know a guy who knows another guy who has 8000Ks on his TL....supposed to meet him tonight.
4300k, 6000k, 8000k, they all burn at the same THERMAL temperature, but their COLOR temperatures are different.
if you want to prove it, convert 4300k, 6000k, and 8000k to Fahrenheit. Your car would melt if those were THERMAL temperatures.
it's not like going from regular 35w halogens to super 100w halogens, where the bulbs actually pull more power.
6000K is bluer, not whiter. The higher up in K you go, the less useable light you will have, and more of a blue tint. I like the way the 6000K bulbs look on the TL, I'd go that route.
BlingBling INSPIRE 32V
![](http://www.xenon-hid.com/images/eyes.jpg)
wait..so 6000k bulbs are plug and play into our cars? We don't need a conversion kit or something? Cuz theres a groupbuy going on at aw.com for 6000k conversion..is that just bulbs then?
you guys should read this site b4 buying anything higher than 6000K.
http://www.intellexual.net/hid.html
8000 k is just asking to get pulled over..
And you get less brightness and give more glare to other passengers..
Look at the 4100k Bulb in this Prelude BELOW:
![](http://www.intellexual.net/faq/46.jpg)
![](http://www.intellexual.net/faq/47.jpg)
THAT SH|T IS BRIGHT AS HELL..
If you want the perfect brightness but also want more of a blueish tint, GET 6000k.. Its a good Compromise between 4000k - 8000k
Don't even go looking for 8000K unless if you want the brightness of a halogen bulb. Some of you guys need to do your homework. Different light bulbs have different light color on the road with the same color temp (K) rating. Some 6000K look blue, purple, and very purple. Heck, some 5000K bulbs even look green.
Just make sure the HID bulb you get is OEM D2R replacement that's genuine and not home-made.
ACURA 3.2tl 2k
2G TL Photograph Gallery
02-25-2002 06:07 PM
