long term storage
Old 01-04-2003 | 11:00 PM
iliveinapathy's Avatar
long term storage
i will be going away for between 3 to 8 months and will have to store my car in the storage garages.
anyone have any recommendations for what to do to as preventative maint?
a) no need for car cover in garage?
B) oil change
c) fill up the gas)
etc etc?
thanks
abe
Old 01-04-2003 | 11:24 PM
car_lost's Avatar
im really not sure but i know this has been covered before so if u search im sure you'll find what you need. good luck!
Old 01-04-2003 | 11:35 PM
Mr Hyde's Avatar
What I would do
1) Oil change
2)Wash and Wax
3) full tank of gas with fuel stabilizer added to it
4)Bump up air pressure in your tires to near max and park the car with all 4 tires on planks of wood to prevent flatspotting
5) Park the car with the parking brake OFF
6)Disconnect the battery
7)Car Cover if you have it.
When you get back Id reconnect the battery(store those radio/nav antitheft codes somewhere safe), decrease the tire pressures, change the oil again, and wash her.
Old 01-05-2003 | 02:28 AM
why the barking brake off?
also isn't it a b*tch disconnecting and reconnecting the battery? will it make that much of a difference?
Old 01-05-2003 | 03:53 AM
AcuraTLFan's Avatar
Disconnecting and reconnecting only requires a 10 mm wrench and a couple of turns...nothing hard about that.
Although you're not using your car, there will still be current drain. Not very much, but over time it adds up.
My dad usually goes on trips for about 1 month intervals and when he comes back, the battery always chocks on him.
Old 01-05-2003 | 12:54 PM
Mr Hyde's Avatar
To prevent the rotors from rusting and binding up the pads.
Also if you can jack up teh car on 4 jackstands that is the best method of preserving the tires, and 4 jackstands is some $$ now, but its cheaper than just 1 tire later on.
Old 01-05-2003 | 10:18 PM
EmuMessenger's Avatar
I've got a cover, new, never used and in the box. PM if you are interested.
baelim
05-10-2018 09:53 AM
dirleton
20
10-16-2015 01:48 PM
spoiler900
10-10-2015 06:48 PM
Froid
09-27-2015 06:16 PM
Desert Ridge
09-27-2015 02:37 PM
Quick Reply: long term storage
