Long Island TLS owners - Intake ???
What's up fellas, question on the Injen CAI and bypass valve. Already did a search and couldn't really get a clear cut answer.
Are the TLS owners on Long Island putting bypass valves on their CAI's? Does it affect overall HP gains at the wheel? Any benefit to cutting the 1 pc (cause the 2 pc doesn't fit TLS') and leaving it short with a heat shield hence no need for a bypass?
Well, I'm not far from LI... and I'd venture to say that almost all of the people from the N.E. who have a CAI have the by-pass. All you need to do is read NSXNEXT's post to see that it's $40 well spent.
There's not proof about it affecting or not affecting HP, some say you lose about 1hp, some say you lose nothing... either way, it's a good investment.
Leaving it as a short ram makes no sense. If you want a short ram, then you should just buy a short ram. A CAI gets more power then a short ram since the filter does not sit in the engine bay.
Here's some reading on the by-pass:
http://www.acura-tl.com/forum/showth...ghlight=bypass
And here's NSXNEXT's thread:
http://www.acura-tl.com/forum/showt...?threadid=43924
Re: Long Island TLS owners - Intake ???
Yes, you can use the bypass on the InJen and you are correct about the 2pc with bypass. You do not need to cut it since it already comes that way and makes it easier to mount the bypass.
If you have any other questions, feel free to email me.
Regards,
Cuong
So I think Cuong must know what he's talking about, but I just want to be absolutely sure of what I'm getting myself into. I just want to avoid cutting the intake if possible. Otherwise, I'll probably just go with the 1 piece, cut it, add bypass and be done.
-Rich
Re: Re: Long Island TLS owners - Intake ???
OK... I was going through some old emails while cleaning out the "mailbox".... you have to cut the pipe... the 2 piece will not fit the new TL's. You'll need to buy the one piece and cut it... just like the AEM. If you's still like to confirm wit Tim.... send him an email at sales@acura-tl.com .... that's the quickest way to get a reply as he doesn't check the individual forums too much.
rmarin - you sure it's so low? I remember seeing dynos showing ~6hp to the wheels. Still not a lot... but more then 1hp....
-Rich
I'll let you know what I find out.
As per Cuong......
The injen 2 piece intake DOES NOT fit the TL Type-S. TLS owners have to buy the 1 piece and cut it for the bypass. Hope that clears up any confusion we seem to keep having.
looks like I'll be doing some cuttingX!
As per Cuong......
As per Cuong......
Having said that, bring on the CAI w/ bypass! Looking forward to my first mod.
Originally posted by rmarin2
I believe it's somewhere around 1 and 5HP. I saw someone posted a dyno of their car with intake, headers, and exhaust and it came up around 295HP or so at the crank. I figured it tallies to be about 5+30+2 approx. I mean i could be way off here but if memory serves I think its very minimal. Certainly not the 10 to 12HP AEM claims!! Someone please correct me if I'm wrong though!!
-Rich
-Rich
When you add mods, the gains are not cummulative... meaning, adding Headers and an intake, which, by claims would net around 40HP (let's say 30hp for headers and 10hp for intake if added seperately) does not actually produce 40hp.. the numbers may only dyno at 36hp.
However, if you add each item individually and w/o the other, you may see the advertised gains. As an example, if you added the intake only... you may have show a 10hp gain on a dyno. Then, if you removed the intake and installed the Headers only you would show 30hp. But combined would not ADD up to 40hp.... it may only show 36hp. Does that make any sense? I hope I explained it clearly..... Anyway, just some food for thought.....
cycdaniel
12-17-2019 10:58 AM
darksky
09-05-2015 03:11 AM
